Measurements with V codes and X codes?
Old Sep 28, 2013 | 05:25 PM
Ultraboy's Avatar
Ultraboy
Does anybody have ground to bottom of fender measurements with the V codes and/or X codes on a V10 excursion without any other suspension mods? Please also include what size tire you are running.
I'm tyring to decide which front springs to go with, and have to make sure it fits under the garage door when completed! Thanks.
Old Sep 29, 2013 | 12:04 PM
LivingLarge's Avatar
LivingLarge
I don't remember what that measurement was on my previous Ex, but I will tell you that I had 1.5inches before hitting my standard size garage opening with V's and 285's.
Old Sep 29, 2013 | 07:25 PM
WE3ZS's Avatar
WE3ZS
Ultra, I have the extra leaf on my X codes so my setup is more than you are asking and I got 3 7/8" lift on my frontend with my swap.
I also have this info from my notes from years ago on this site by "bruce1954". These ride height changes are all based on new springs and may vary a bit based on exactly how worn out your stockers are and or if you use used springs and how much settling they have.
Spring code...... Capacity...... Rate...... Travel...... V-10 EX...... PSD EX
"B" V-8 stock.... 4100lbs........ 330........ 5.02"...... -0.25"......... -0.66"
"C" V-10 stock.. 4300lbs........ 350........ 5.01"........ 0.00"......... -0.37"
"D" PSD stock... 4700lbs........ 380........ 5.14"....... +0.33"......... 0.00
"V" .................5200lbs.........430........ 5.13"........ +1.77"........ +1.5"
"W" ................5600lbs........ 450........ 5.34"........ +2.77"........ +2.52"
"X" .................6000lbs........ 470........ 5.54"........ +2.90" ........+2.68"
Hopefully this will help some.
Tinman27
Feb 24, 2014 11:14 PM
RKraft
Oct 25, 2013 07:44 AM
robert_l_ross
Jan 3, 2012 11:19 PM
brownie83
Mar 9, 2009 09:06 PM
famfun
May 21, 2008 11:06 PM
