V-Codes or Add-a Leaf
Old Mar 9, 2009 | 07:06 AM
brownie83's Avatar
brownie83
hey guys...
i know this has been tossed around here...but i could not find a definative answer. Are a total V code spring swap better/worse than a front add a leaf? will the add a leaf settle over time, but if i get a "used" set of v codes, wont they be saggy? i found a set of v codes in a junk yard, the guy says they are v codes, but how can i verify? let me know...im constatntly bottoming out, and want a little height. thanks for all the great help...
Old Mar 9, 2009 | 01:37 PM
BostonX73's Avatar
BostonX73
From what I was told, if your stock springs are already sagging down to the bumpstop, replace them, don't just put on an add-a-leaf.
If the V codes have 100K miles on them, you may want to stay away from them - unless they are really cheap and you just want to them.
The chart says the V will give a V10 1.75" of lift, PSD 1.5"
so even a well used set should get you off your bumpstop and improve the ride some.
Old Mar 9, 2009 | 09:06 PM
wallz's Avatar
wallz
For the price and the piece of mind, unless you can get a super deal, I think it is still just better to go new. I always think that when replacing something on the truck it makes more sense to replace with something better than to go back to what was!
I just replaced with the v and b code springs with the 3.5" tapered block in the back.
Big_Al59
Dec 18, 2015 02:21 PM
Krisx125
15
Sep 8, 2012 11:33 PM
IROCKWITHDIRT
Mar 20, 2011 03:21 PM
BigPigDaddy
May 15, 2010 12:02 AM
rvx290
2004 - 2008 F150
May 11, 2010 07:35 AM
