V/P codes?
V/P codes?
So while calling around today, I found a local recycler that has a 2004 F250 diesel with 52000 miles that has a suspension code on the sticker of V/P.
He's selling all 4 springs for 450.
I was contemplating a V code + 3.5" block, V + B code or V + modified B code.
Does anyone have any info on P codes for the rear?
My situation is a 2000 V10 Excursion...fronts are wasted, and with my day to day gear in the back, right now it sits just a bit down in the rear. I also have to tow a 16' enclosed trailer...I'd estimate the tongue weight to be between 760 and 860lbs, but I use a multi-ball hitch that puts the ball out a good 9" from the normal placement. As it sits now, I get about in inch to an inch and a half of sag when towing.
I'm hoping to get level when towing (with my day to day gear in my truck and existing trailer), and to not raise the truck too much (still gotta get inside parking garages). I would consider an inch of 'rake' acceptable with my day-to-day gear, but I don't want to go over that.
He'd sell me the fronts for 250 if the P's will make the rear too high.
Thoughts? Mileage on the springs acceptable? Height of the P codes vs. B codes vs. 3.5" blocks?
https://www.ford-trucks.com/forums/1...spring-id.html
I found some used F350 springs with these codes above. Not sure that helps, but the codes most guys here know are the ones for new springs from FORD. Seems those codes are different than what's stamped on the factory spring.
Then again, they are coming off of a diesel 4X4 250. The diesel motor is heavier than my V10, but I added a little with the front tow hitch.
I'm hoping that the P codes would work in the rear since I carry maybe 200lb of 'daily' load in the back all the time (the storage box I made, tools, SAR gear, subwoofers, etc.).
I'd hate to get these, find out I have like 3" of rake, then not be able to get rid of them.
If someone had 'new' B codes and could tell me the distance from the center of the bushings to the bottom, I'd at least have a reference.
Found this with a quick search:
https://www.ford-trucks.com/forums/5...ml#post5980321
If that 8,800lb rating is correct, then according to this info I have saved:
The P's are rated higher than the C's are.
Hope that helps.
Stewart
Rear spring codes:
A = F-250 & Excursion (6,084 pounds @ground)
B = F-350 SRW (6,830 pounds @ground)
C = F-350 DRW (8,250 pounds @ground)
Hope that helps.
Stewart
Hope that helps.
Stewart
Hope that helps.
Stewart
73ferdf250highboy
18
07-24-2013 11:05 AM
wbuffetjr1
03-28-2011 09:07 PM
