Navigation
Old Sep 26, 2013 | 06:46 PM
Cold One's Avatar
Cold One
Navigation
My wife recently switched from a Toyota to a 2013 F-150 FX4. It has my ford touch but lacks navigation. After several searches I cannot find out if we can add nav to the factory system or need to replace the whole system. Can someone point us in the right direction? Thank you in advance for your help!
Old Sep 26, 2013 | 08:47 PM
irishguy824's Avatar
irishguy824
I am no expert, but I think as long as you make sure the navigation that you buy works with Sync, it should be just fine.
You can also buy the navigation unit that comes from the factory.
Old Sep 26, 2013 | 08:49 PM
whitetmw's Avatar
whitetmw
I believe that the Navigation can be added via the BCM In-Put by the Dealer. Providing the Radio is capable along with the center display.
Tom
Old Sep 26, 2013 | 08:50 PM
whitetmw's Avatar
whitetmw
O'h... You're much better off with a Garmin or other brand. The radio provides only Voice Commands without Directional Display other than four or five caricatures on the Speedometer and Display Board.
Old Sep 26, 2013 | 11:24 PM
ralphhood3's Avatar
ralphhood3
Whitetmw, what do you mean? The MyFordTouch has better mapping and directions than any factory or aftermarket nav system I've ever owned, and I've owned probably 25 from $99 jobs to $4500 systems.
You sure you're not referring to the home screen where you only see the compass and directional arrows versus when you actually hit the map tab and see the full screen map? Even in major cities you get 3D views of buildings and added features like that. I've used garmins, and I can't imagine how it'd be preferred over the MFT Nav, so I'm assuming the limited directional indicators you're referring to means you might just be thinking the home screen view versus the actual map screen.
Ralph
Old Sep 27, 2013 | 07:46 AM
FordIVTteam's Avatar
FordIVTteam
Official Ford Rep
Hi Cold One,
Although I cannot advise on any aftermarket solutions, I can confirm that the MyFord Touch system cannot be "upgraded" to include navigation. Your dealership would be the best point of contact to discuss any other options available for your vehicle.
Antonio
Old Sep 28, 2013 | 07:13 PM
Cold One's Avatar
Cold One
Thank you all for your help. We will be looking into a new nav unit. We have a garmin but was looking for a more integrated one.
Old Sep 28, 2013 | 07:24 PM
Cold One's Avatar
Cold One
One more question. What is the optional sd card navigation that is available through the dealer?
Old Oct 1, 2013 | 01:45 PM
FordIVTteam
Official Ford Rep
Cold One,
The SD card used with the MyFord Touch system is where the navigation data is stored. All the maps, addresses, and business information the system uses is housed on this device.
Antonio
Old Oct 1, 2013 | 06:45 PM
Cold One's Avatar
Cold One
Thank you for the response.
98explorerltd
Feb 6, 2019 12:17 PM
79trailerspecial
Jun 9, 2006 10:27 AM
gohskrsutah
Car/truck Buying Advice
Mar 1, 2005 01:45 AM
brad605
Aug 6, 2004 05:58 PM
jscozz
Jul 21, 2004 10:53 PM
