The homeless bracket
Old Sep 27, 2013 | 08:09 PM
Ninra's Avatar
Ninra
Sorry about the lack of details
So it's an 89 F250 with a 351w and a E40D tranny (evidently). I just got it, rescued it from a farm. It hasn't been inspected in 6 years and the former owner evidently knew nothing about mechanics, electronics, electricity, lubrication, and RADIO'S!
I have an old love for Ford's and this is the first one that I have actually owned, but some of my best memories are in an 84 F150.
I'll be sure and include the details in the future. Even though I've been on the Internet since 92, I haven't been a member of a forum since the WWW took over.
Old Sep 28, 2013 | 09:06 AM
bashby's Avatar
bashby
You can click on "user cp", then "edit signature" then put the truck details in your sig so it shows up on all your posts.
Old Sep 28, 2013 | 10:09 AM
Ninra's Avatar
Ninra
Soon, very soon
Alas, I am a newb and am not allowed to have a signature until I prove my worth. Hopefully I will be found worthy and have the honor of a signature bestowed upon me.
Old Sep 28, 2013 | 10:34 AM
UNTAMND's Avatar
UNTAMND
25 posts for a signature.
Go read a bunch of stuff, ask questions, give your feedback and experience.
Find your local chapter and start up a conversation and you'll rack up posts in no time.
Old Sep 29, 2013 | 05:26 PM
Ninra's Avatar
Ninra
OK, so what does it do?
So what does the TV cable do? Where is the connection and should it be something I need to fix?
Old Sep 29, 2013 | 09:38 PM
UNTAMND's Avatar
UNTAMND
Your transmission is all electronic, and you don't need to have the "kickdown" cable to let the trans know where the throttle position is.
Old Sep 30, 2013 | 06:25 AM
dixie460's Avatar
dixie460
A TV (Throttle Valve) cable runs from the throttle to some linkage (and eventually, by this linkage, to a valve inside the transmission) and provides for the "kickdown" feature on auto transmissions. That's when you punch the throttle while cruising, and the trans will kick down into a lower gear for better acceleration. Just like downshifting a manual... except you don't have to think about it... or do much of anything really... and it's BORING!
On some auto transmissions like the Ford AOD, the kickdown cable also adjusts the hydraulic pressure inside the transmission, known as line pressure, which is used to apply clutches (among other things). Not adjusting the kickdown cable correctly on an AOD usually = death for transmission.
But don't fret! As was mentioned... the line pressure, kickdown feature, and almost everything else on your E4OD (Electronic 4Speed OverDrive) transmission is electronically monitored and controlled by the EEC and sensors, with solenoids inside the transmission to make the actual adjustments. Nothing to worry about unless you want to reprogram it with a chip or something.
Old Sep 30, 2013 | 01:15 PM
Ninra's Avatar
Ninra
Thanks for the help.
Thanks for the info. Like I said, I'm not that familiar with the E40D and it just bothered me that there was an obviously empty bracket right at the throttle with nothing around it.
Old Sep 30, 2013 | 01:49 PM
xkpsanit's Avatar
xkpsanit
The bracket is a production efficiency thing, produce one bracket that covers all applications. Less stampings and less parts on the shelves.
PharmerChris
45
Jan 11, 2020 01:08 PM
66v8baby
Oct 27, 2016 10:21 AM
61 uni
13
Oct 30, 2012 07:37 PM
KelVarnson
Oct 26, 2012 10:37 PM
