If the engine remained running I would think from your description that you have transmission issues. CPS intermitently will kill the engine but not make any "gear changes".
No I doubt that a trans problem would kill the engine unless the TQ was locked while in gear. Did not see that engine quit. Might be CPS issue but others way more up to speed than I am will chime in
Thanks for the replies and help, before I left for the day I did notice the positive battery cable on the driver side was loose, I tightened it up, but other than that nothing out of the ordinary, I drove the truck today but with o/d off, so far it drove fine, I will put in a new CPS and see if anything funky happens,
change your transmission screen, gaskets and put in fresh fluid. when you change your cps get one from either your local dealership or riffraff, do not get one from autozone.
Sorry for the late replies and thank for your guys help, I'm fairly confident Its a CPS issue, drove the truck all week with O/D off cause of fear, Thank God I mostly do city driving), Drove perfectly fine, Last night after work, stopped at whataburger, and the truck abruptly died in drive thru, But I fired it back up right away
I have a theory, the skip/jerk I felt on 55 -60 is the engine died (lost signal from cps) and fired back up immediately due from momentum/back push from the tranny
Anyways Im off in 1 day, this weekend anyways I planned to do maintenance to the truck anyways so ill report what happens when I change the cps.
