Project: ThunderStroke
Old Nov 5, 2013 | 02:32 AM
  #46
RacinNdrummin's Avatar
RacinNdrummin
So you just used the stock intake lobe and advanced it two degrees????
Stock spec is exactly the same, except on a 98* ICL.... Events moved accordingly...
Old Nov 5, 2013 | 09:25 PM
  #47
TourqueRise's Avatar
TourqueRise
Yes, but I used the stock specs from the cam spec book for comparison. They showed the stock specs as: ICL 103* Duration 176* Open .050 -15* Close .050 11*. So from those specs the intake event was advanced 7 degrees. The grinder said they had to take off .030" on the intake lobe to get my numbers. Did you find different stock specs?
Old Nov 5, 2013 | 09:34 PM
  #48
RacinNdrummin
I degree'd in two stock cams, and they were both on a 98* ICL. I also had a stock cam run on a cam doctor.
Now, Im not saying your wrong, looking at your specs, seems to me the only difference is the ICL, so its very possible there could be some variation, who knows what kind of tolerance IH held on the grinds....
Old Nov 5, 2013 | 10:45 PM
  #49
TourqueRise
The exh lobe centerline is also different at 109.4 vs 105. Looking at your specs it looks like going off cam book stock specs is quite useless, and that degreeing is the only sure way to know exact specs. Looks like Im going to have to degree my cam, and talk with my cam grinder.
91dirtydiesel
Feb 19, 2012 03:05 AM
dyoung14
19
Jan 20, 2009 08:14 AM
rockmike
4 Cylinder Engines
Dec 10, 2008 07:02 PM
KyleLight
General Diesel Discussion
Oct 10, 2006 07:25 PM
robertleeii
Oct 3, 2003 11:41 AM
