Push Button 4x4 question
Old Sep 22, 2013 | 07:39 PM
Volvo92906's Avatar
Volvo92906
Originally Posted by FlyCool5.0
Okay, forgive me here, im about to ask a dumb question. What is the PTO plate? Last time I used the term was for a pto was a switch on a dump truck we were using. Should I look for a particular bulge on actual "plate" on the right/left side? Ive delt plenty with the tech specs on my auto trans but the manual trans specs will be new for me. Thanks for humoring me guys!
You can see the plate in his picture. It is in line with the cross member on the left side of the transmission.
PTO (Power Takeoff) is the same thing youre referring to, except that switch is what activated it.
Old Sep 22, 2013 | 07:41 PM
dustybumpers's Avatar
dustybumpers
No problem. Yes, same plate. If you look in the picture That I re-posted,the cross member, and wiring harness appear through the middle of the plate. It's that big flat plate with the bolts top and bottom.
ZF transmission has a PTO plate on both sides. No other 5 speed transmission has the PTO plates on it
Old Sep 22, 2013 | 09:54 PM
kawamatt2's Avatar
kawamatt2
Wow Great Amount Of Information There. Thank You. Only difference would be mine being a 4r70w vs e4od. Tricking The computer should be the same with the jumper wires on my 4r70w, correct? Did you swap over the manual computer or did the jumpers you had in the harness keep the check engine light off? Also I take it that the jumpers you installed into the harness to tell the computer it was in neutral were so you could engage 4L?
thanks!
I would think it would be the same regardless of transmission as the transfer case shift module has nothing to do with the transmission itself beyond the ability of the shifter to be in neutral or park.
I did swap to a manual transmission computer. It was actually pretty difficult in my situation as Ford never offered the F150 with 351 and manual transmission. I ended up finding an F250/350 computer to work. I swapped to the manual ECM to make it as "factory correct" as possible and so I would gain various idle qualities that are specific to a manual transmission truck. Regardless, in your situation I don't *think* you will have a check engine light for a missing transmission if you keep the stock computer. I have read mixed reports though.
Yes the jumper (not plural, the other jumper was factory installed in the harness I scavenged from a manual truck) I installed was to trick the ESOF module (not the main ECM) into thinking the transmission was in neutral. That connector picture above is located on the drivers side fenderwell roughly below the brake master cylinder.
I also did some other wiring into the cab to meet with the newly added clutch position switch. I had to add a wire from the C202 bulkhead connector on the firewall back to a pin on the ECM connector so the ECM would know when I have pushed in the clutch (for idle adjustments and idle hang when shifting gears). Had to pull all those wires just to get to and add one wire!
I would look at this thread for more info on the wiring side of the swap.
E4OD -> M5OD computer question - FSB Forums
Hey kawamatt2, I forgot to ask, what model manual did you swap in, m5od-r2? Ive read a couple articles that left me puzzled on the internal/external slave cylinder deal. Do I need to look for any particular transmission that will make the switchover easier when im ready for the swap? thanks !
I went with the ZF5 S5-47 which came in 96' and 97' 3/4 and 1 ton trucks. Any transmission you swap into your truck with the 302 (small block ford) will be an internal slave. Moreover, it doesn't matter which transmission you go with, M5OD or ZF5, all the clutch hardware (master, slave assm., clutch disk, pressure plate) will be the same. If you do the swap, just order all the clutch hardware for your model truck and engine.
You can look at my pictures at this link for pictures of when I rebuilt the ZF and installed it.
Manual Photos by kawamatt2 | Photobucket
preppypyro
1997 - 2003 F150
Jul 28, 2017 12:18 AM
Drakedog
Apr 24, 2017 03:34 PM
dougegoble
Mar 24, 2015 03:15 PM
Bluegrassboy70
Sep 3, 2009 11:29 PM
tommypic
Feb 24, 2009 09:56 AM
