Sponsored by: Real Truck
Front ABS Wires?
Old Nov 16, 2006 | 06:59 AM
DetailerDave's Avatar
DetailerDave
Front ABS Wires?
99 F250 SD. Build date 2/98. I just replaced the exhaust manifold studs on the passenger side. When removing the inner fender liner, I noticed there is an unused wire harness attached to the back of the liner, towards the bottom, towards the frame. It has a small connector. I looked, and found the same unused harness on the drivers side as well. I suspect these wires are for front wheel ABS. Did Ford anticipate adding ABS to the front, and include wiring for it? Or did some models, with a common harness, come equipped with front ABS?
Old Nov 16, 2006 | 07:45 AM
Pocket's Avatar
Pocket
Not all models come equipped with 4 wheel abs. But yes that is the harness for it.
