55 Ford C600 COE VIN number help please
Old 09-19-2013, 05:48 PM
55 Ford COE's Avatar
55 Ford COE
55 Ford COE is offline
Hello, can anyone shed some light on the possible alternate location of my VIN number. I need to match the vehicle to the title. The glove box tag is damaged. Thank You
Old 09-19-2013, 05:52 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
On the pickups I have found them on the front cross member at one side or the other........kinda next to the radiator. Might check there.....COE might be different though.
Old 09-19-2013, 06:34 PM
55 Ford COE
Thanks for the suggestion, I will start looking on that crossmember
Old 09-19-2013, 06:52 PM
old uhaul's Avatar
old uhaul
old uhaul is offline
Most trucks have the vin stamped on the top of the passenger frame rail,ahead of the cab mount.
Some trucks were not stamped at all
Old 09-20-2013, 10:49 AM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is online now
My 54 is stamped near the passenger side Front Crossmember. I was looking for my VIN on my 56 Panel in the same location and figured it wasn't stamped but when cleaning the frame it was stamped in front of the front cab mount passenger side. Both were, as posted above, on the top of the frame rail.
Also, as posted else where on FTE, the true VIN is the one on the frame rail NOT the glove box plate. You can get the plate reproduced by several vendors.
Old 09-20-2013, 10:56 AM
55 Ford COE
Thanks for the great reply info. I will again focus in those areas mentioned. Can you list a vendor that reproduces those glove box plates.
Old 09-20-2013, 11:21 AM
bjmayberry2
Old 09-20-2013, 11:29 AM
55 Ford COE
Great info!! Thank You
Old 09-20-2013, 11:53 AM
bjmayberry2
From Tags Backeast, Trim Tags Backeast, Data Plates, A.G.Backeast. We make tags for AMC, Buick, Cadillac, Camaro, Chevelle, Chevrolet, Chrysler, Corvette, Dodge, DeSoto, Edsel, Ford, Frazer, La Salle, Henry J, Kaiser, Lincoln, Mercury, Mustang, Oldsmobile aka AG Backeast:
I just need rubbings or pix of old tags with the codes wanted written off to the side to be sure.
The price is $100 per tag. ie. $200 for two tags.
Send a check to
BRETT STOUTENBERG
P.O.Box 40011 Grand Junction, CO 81504
Turn around about 1 week
Old 09-20-2013, 12:21 PM
55 Ford COE
Thanks, I will be in contact over within the week.
Old 09-20-2013, 01:26 PM
harleymsn's Avatar
harleymsn
harleymsn is offline
Note that you MUST have a valid title in your name for that VIN before they will make a plate for you.
Old 09-20-2013, 04:45 PM
55 Ford COE
Good point. I do have the title.
The reason the data plate replacement will help is US customs needs to verify the title to the vehicle in order to stamp it for export. (Truck in US, I am in Alberta). The alternative is trying to locate the VIN on the frame which is possibly an exercise in frustration.
Old 09-20-2013, 04:47 PM
bjmayberry2
You still want to find the VIN on the frame. They may want to look at that as well.
Old 09-20-2013, 04:53 PM
55 Ford COE
Yes I agree that will be good insurance as well
55 Ford COE
Large Truck
09-19-2013 04:45 PM
cruisetopdown
25
04-27-2012 07:01 AM
taylor17
Large Truck
10-31-2010 01:55 AM
mercurycat
1947 and Older Ford Trucks
02-28-2010 10:59 PM
nugget37
07-21-2004 09:02 AM
Quick Reply: 55 Ford C600 COE VIN number help please
