P2262 code
Old Sep 24, 2013 | 07:21 AM
tcjhkbjt's Avatar
tcjhkbjt
ok im new to the diesel world. how do I check the psi on the Map sensor to see if it changes when I blow into it?
Old Sep 24, 2013 | 07:28 AM
npccpartsman's Avatar
npccpartsman
You'll need something to monitor the PCM. Scan Gauge II, Dash Boss, Edge Insight are the more economical ones. More professional would be Auto Enginuity but costs a bit more. They plug into the OBDII port and let YOU see what the PCM is seeing. Very important in diagnosing problems on a 6.0.
Pull the rubber hose from the MAP sensor and intake and check the hose and intake nipple for blockage.
Old Sep 24, 2013 | 05:32 PM
tcjhkbjt's Avatar
tcjhkbjt
I don't have anything to check the psi
Old Sep 24, 2013 | 06:36 PM
m-chan68's Avatar
m-chan68
Okay, perhaps I'm being misunderstood. I made the suggestion of disconnecting the rubber hose at the intake manifold (BUT WITH THE OTHER END STILL CONNECTED TO THE MAP SENSOR) and blowing into it, while observing the live data reading for MAP psi (or MGP psi), also with your Scan Gauge or whatever electronti gizmo you have that can read the MAP psi data with. The purpose of this test, was to see if the data changes or responds to you blowing into the hose, while the ignition is in the RUN position, and while watching the reading. If it changes or responds as you're blowing into it, it likely means the MAP sensor is functioning (provided it reads the same, or close to EBP_A and BARO psi readings at key-on/engine-off). Hopefully I've clarified things a little.
Old Sep 29, 2013 | 05:35 PM
tcjhkbjt's Avatar
tcjhkbjt
I checked the hose and it is clear. When I removed it from the intake manifold and noticed the port on top there was clogged a little so I cleared it out with a paper clip. Put it all back together and drove it, I got on the gas and noticed a lot of black smoke that came out of the tailpipe, and it seemed to run better. Question, my check engine light is still on. Does it need to be cleared or will it go away on its own
Old Sep 29, 2013 | 06:40 PM
Yahiko's Avatar
Yahiko
If all the reasons for it coming on are solved they it will reset it self
after so many drive cycles.
Sean
Old Sep 30, 2013 | 07:15 AM
tcjhkbjt's Avatar
tcjhkbjt
great thanks
johnblade
Jan 2, 2014 09:04 PM
propellerhead
1983 - 2012 Ranger & B-Series
Jun 14, 2013 08:14 PM
cardone
1997 - 2003 F150
22
Apr 5, 2006 07:19 PM
rebel_ford4x4
Exhaust Systems
Jul 28, 2004 01:30 PM
dvsmnstr
Apr 5, 2004 12:27 PM
