gears ?
Old Sep 18, 2013 | 08:13 PM
therigwelder's Avatar
therigwelder
gears ?
trying to figure what gears I have.I own a 94 f 450 powerstroke with a 5 speed.the tag is missing on the diff.what is the most common rear end in this truck.thinking about changing the gears for better MPH.
Old Sep 18, 2013 | 08:22 PM
'89F2urd's Avatar
'89F2urd
pull the cover and count the teeth. you can jack up the rear and count the turns of the yoke in relation to the turns of the wheel, but counting the teeth is the best way to be definitive.
Old Sep 18, 2013 | 08:57 PM
bashby's Avatar
bashby
If you're going to pull the cover, the # of teeth are stamped in the ring gear. doing the driveshaft thing will work also. If you turn the driveshaft 10 times and have someone else count the wheel rev's you can get a pretty accurate reading. With an open (non limited slip) rear end, if you have one wheel on the ground and one jacked up, the wheel will spin at double speed, so a 4.10/1 ratio would equate to 8.2 wheel revolutions to 1 driveshaft rev.
Old Sep 18, 2013 | 09:19 PM
Encho's Avatar
Encho
The Southernmost Mod
3.04 and 3.55 are the most common gears in these trucks, but do follow what has been said.
Old Sep 18, 2013 | 09:30 PM
Conanski's Avatar
Conanski
Originally Posted by Encho
3.04 and 3.55 are the most gears in these trucks,
In an F450... hardly, you're more likely to find 4.56 or 4.88.
Find the axle code on the calibration decal on the drivers door pillar and cross reference it in the owners manual or post it up here.
Old Sep 18, 2013 | 09:48 PM
Encho's Avatar
Encho
I saw a F-150 there (thanks for the correction)... Anyway, the question has been properly answered already .
Old Sep 19, 2013 | 10:42 AM
tjc transport's Avatar
tjc transport
i ain't rite
that F-superduty (it is not a 450) has a Dana 80 rear axle in it, and the gear ratios were 4.63 and 5.13.
i bet it has 5.13 gears in it, cause the 4.63 was not a popular gearset.
if it still has th truck info tag on the driver side "B" pillar, post up the axle code and we can tell you what it came with.
Old Sep 19, 2013 | 10:45 AM
Phy's Avatar
Phy
Assuming it's an F-Superduty, it has a Dana 80 with either 4.63 or 5.13 gears.
Old Sep 20, 2013 | 12:11 PM
therigwelder
Ok I am going to have to pull the cover and count the teeth.the Sticker on the pillar is gone to.what is the best gear ratio to use for mpg?I no longer need the truck for heavy hauling
Old Sep 20, 2013 | 01:19 PM
Diesel_Brad's Avatar
Diesel_Brad
Then sell the truck and get something lighter duty.
4.63 would be the best Stock gear for fuel economy, but 4.10 or 3.73 would even do better
TheTowingCowboy
May 25, 2010 09:42 PM
lonerangerinaz
Nov 21, 2009 05:31 AM
Gold Dog
Jan 5, 2006 08:31 PM
RobertJohn
Jan 24, 2005 10:21 PM
Boss50
Mar 9, 2003 09:56 PM
