Modular V10 (6.8l)
drive line clunk?
Old Oct 4, 2013 | 01:49 PM
cole1996's Avatar
cole1996
So how do I grease this up? I don't see any zerks or anything.
Old Oct 4, 2013 | 01:51 PM
cole1996's Avatar
cole1996
Originally Posted by paul
When mine gives a little clunk from a stop I know it is time to re-grease the slip yolk on the rear drive shaft... It is also a good time to replace the boot to seal it up and keep all the grunge out.
So how do I re grease this up? There's about 1/4" of play up and down (vertical) on there.
Old Oct 4, 2013 | 08:22 PM
paul's Avatar
paul
Normally you remove the driveshaft, cut the bands for the boot and pull the yoke off. Clean everything up, repack it with grease and install a new boot. With a 1/4" up and down play the yolk and spline shaft may be worn out. You may have to replace both which will require a trip the the driveline shop to cut off the old and weld in a new spline shaft. When you put it all back together remember to "time" the driveshaft making sure the u-joints are perfectly in line (parallel) between the shaft and yoke. If not timed the driveshaft will give you a nasty vibration.
Old Oct 4, 2013 | 09:09 PM
cole1996's Avatar
cole1996
I mean 1/4" total movement. Like 1/8" each way maybe*.
Looks really dry under there also, but I don't really wanna mess with anything.
Is there gonna be long term damage if ignored?
Old Oct 4, 2013 | 09:48 PM
knightrider955's Avatar
knightrider955
Just had my Shaft redone, New yoke, All U joints, the rubber ball thing at the front of it, And balanced. Cost 370 installed. Its never driven so smooth since I had it done. The play in the yoke causes Harmonic vibration that you may or may not feel. This can ruin you rear end and has been known to break the end of your T-case right off. I never noticed the vibration until I had the shaft redone and it was gone, what a differance. I had the clunk and a bad u joint. I greased my yoke but after awhile the grease wouldnt work anymore.
otter 1
1997 - 2003 F150
Jun 13, 2017 09:39 PM
TheRooster
Jan 24, 2017 08:24 AM
tylerhughes
Oct 25, 2011 09:29 AM
fordbroncodave
1978 - 1996 Big Bronco
23
Jul 9, 2009 03:10 PM
Gf2501
Mar 22, 2006 02:48 PM
