Dana 60 clunk
Old Jan 23, 2017 | 10:48 AM
TheRooster's Avatar
TheRooster
Dana 60 clunk
I've been getting a clunk when going from reverse to drive or drive to reverse.
I greased the splines on the transmission output shaft and replaced the ujoints. When reinstalling the driveshaft I noticed good amount of slack in the rear differential input shaft. I can rotate it probably an inch in either direction.
I assume this is where the clunk is coming from. There is no whine really (at least not anything I can hear over road noise).
So I'm guessing this isn't exactly normal, but should I be saving up for a rebuild or is it going to be ok?
Old Jan 23, 2017 | 07:15 PM
blageurt's Avatar
blageurt
Take the cover off the rear end and see how much metal there is ....and obviously examine the fluid for metal particles.......
Old Jan 23, 2017 | 07:22 PM
Im50fast's Avatar
Im50fast
Every rearend I've had my hands on has an inch of play. It's normal.
My van has done the same/similar clunk since I got it at 113,000miles. It's now at 286,000.
Mine also clunks as I near a stop while decelerating or braking. In neutral or Drive: same thing. Does yours?
Old Jan 24, 2017 | 08:24 AM
TheRooster's Avatar
TheRooster
Yeah mines pretty much the same, 130,000 on this one. That makes me feel a lot better.
I'm still going to remove the rear cover and replace the diff oil as Balgeurt suggested just for peace of mind. It's a church van so I'm assuming that gear oil is roughly 130,000 miles old.
After that the only concerning noise I haven't fixed or nailed down is what I believe to be a rattling torque converter in park, may just have to live with that supposedly they will live a long time like that.
dhoff024
2015 - 2020 F150
Aug 5, 2017 12:31 PM
otter 1
1997 - 2003 F150
Jun 13, 2017 09:39 PM
demonhead
Modular V10 (6.8l)
19
Oct 4, 2013 09:48 PM
nojeffgordon
1978 - 1996 Big Bronco
Dec 21, 2006 09:09 AM
Gf2501
Mar 22, 2006 02:48 PM
