Battery light coming on
Old Sep 16, 2013 | 11:19 PM
Randy777's Avatar
Randy777
I took a 1200 mile road trip last week and my battery light would come on while cruising for maybe 4 or 5 minutes then go out. I thought it might be the alternator but my scan gauge still reads 13.4 to 13.5 volts so doesn't this mean my alternator is still working ok.
Old Sep 16, 2013 | 11:32 PM
BLADE35's Avatar
BLADE35
Yes still working but a Diode usually is Going Bad In the Alt for Random Bat Light that still has Strong Crank
Get a Battery Hydrometer and test bat cells its Very Accurite
You may need Both an Alt and Batterys they sometimes Kill each other
It would be a Great time for High Output alt
Old Sep 16, 2013 | 11:34 PM
BLADE35's Avatar
BLADE35
Oh Clean ALL Cables and Connects Good even grounds follow them to where they mount Both Ends and Clean them
Its worth a Shot IMO First to clean if you haven't tried
Occ this works or you find a Bad Ground wire or something
Old Sep 17, 2013 | 12:13 AM
Bonanza35's Avatar
Bonanza35
I just had an alternator installed on the road. It is only putting out 12.5 volts and the hot wire always seems hot. I mean really hot to touch. Is this alternator bad too? Also installed new batteries month ago.
LeoJr
Dec 18, 2015 08:42 AM
Dirtmetal
Mar 28, 2011 06:21 PM
hdman6
Mar 30, 2009 05:14 AM
indebt
Aug 29, 2007 06:55 AM
ALF1999
Aug 24, 2007 08:07 PM
