HOT alternator !
Old Sep 16, 2013 | 05:24 PM
landshark69's Avatar
landshark69
Question HOT alternator !
sorry false alarm ! SUPER NOOB !
Old Sep 16, 2013 | 05:38 PM
69cj's Avatar
69cj
Glow plugs will pull 200+ amps not counting the starter. Some discussions on wether the alt. is connected before or after the gpr drops out. If your charging after app. 2 min. then you should be OK. You need a Scangauge ll at a min. to monitor what's going on.
Old Sep 16, 2013 | 05:44 PM
npccpartsman's Avatar
npccpartsman
The alternator will get hot quick just after you start your truck and the glow plugs cycle. It's putting out a lot of amps to recoup what the batteries used to heat the glow plugs to start.
Old Sep 16, 2013 | 06:32 PM
landshark69
will the scan gauge ll read trany codes as well ? and yes it seemed to be a false alarm on the alt ! thanks
Old Sep 16, 2013 | 06:39 PM
npccpartsman
No, it won't read transmission codes
Old Sep 16, 2013 | 09:45 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
When I load tested my Tenney alternator to 240 amps my temp gun was showing the alternator was over 300 degrees Fahrenheit!
Old Sep 16, 2013 | 11:21 PM
Yahiko's Avatar
Yahiko
The stock 110 G6 will in the first two minutes jump up
to 200F if you are pointing the laser dot at the windings
inside the alternator.
And I hate to brake a myth but the alternator starts charging
as soon as the engine is spinning. It just has a large deficit to
overcome so it looks like it not doing anything.
The reason I know this is because I put a clamp meter on the
alternator output wire and it starts showing output as soon as
the engine is running on it's own. I was going to post a video clip
of it beck some time ago but someone else posted just about the
same time/ So I just skipped it.
Sean
Old Sep 17, 2013 | 12:30 AM
Bonanza35's Avatar
Bonanza35
So what was the 110 G6 putting out? I'm thinking mine is low with 12.5 volts?
Herb Bell
Aug 2, 2019 11:21 PM
JaySVX
Sep 26, 2012 08:31 PM
429poweredf350
Feb 8, 2011 01:47 AM
jle70
13
Sep 29, 2008 05:17 PM
jad4
Aug 1, 2008 01:44 AM
