Sponsored by: Real Truck
battery light?
Old Aug 23, 2007 | 10:30 AM
indebt's Avatar
indebt
battery light?
so my battery light stays on and manuel says charging system is bad. What do I check?
Old Aug 23, 2007 | 10:36 AM
badblueoval4life's Avatar
badblueoval4life
alternater maybe just guessin
Old Aug 23, 2007 | 10:44 AM
fbilly420's Avatar
fbilly420
check the alternator output. If you have a volt meter put ground lead on battery ground and the pos. lead to the heavy gauge wire on back of alt should be about 14.5 to 14.7 volts if it is less than that i would look for bad connections or replace the the alt.
Billy
Old Aug 23, 2007 | 11:13 AM
zx250's Avatar
zx250
Of the next Riffraff East
Or you could just go to one of the discount auto stores like AutoZone and have it tested for free. I'm betting you due for a new alternator.
Old Aug 23, 2007 | 11:32 AM
pctjk's Avatar
pctjk
Along with having the alternator tested, might as well have the batteries load tested also, check the battery posts and clean them, check your battery cables for corrosion.
Old Aug 23, 2007 | 02:54 PM
Lovin7.3's Avatar
Lovin7.3
that just happened to me a couple days ago. it was the alternator and a bad batt.
Old Aug 24, 2007 | 06:34 PM
indebt's Avatar
indebt
So I get on the freeway today and punch it to shake off this dude tailgating me and the light goes off and voltage goes to normal. It almost didnt start this morning so I think something is loose since by launching the truck everything went normal!
Old Aug 24, 2007 | 06:36 PM
zx250's Avatar
zx250
That sure does sound like a failing alt. The higher rpm's will help the alt make more volts. Get it changed before it ruins your batteries.
Old Aug 24, 2007 | 06:37 PM
ron's power stroke's Avatar
ron's power stroke
sounds like cable cleaning is in order for saterday
Old Aug 24, 2007 | 06:46 PM
spinge's Avatar
spinge
Did the light stay off, and the voltage stay normal? If so, I would say a loose/bad connection someplace, otherwise it is probably the alternator. I heard a while back that there was a problem with the small connector on some of these alternators. I had a similar situation about a year ago, and it was the alternator. Higher RPM=more power generated. This is normally modulated by the regulator, but when the alternator goes flat, you are only getting decent power out of it at high RPM's. Back down at idle, the power drops back off, and the light comes back on.
One word of caution - even if you get your alternator tested at a "discount store", beware of the parts. Until I got a genuine Ford alternator, I put 3 discount alternators on in 2 weeks.
Old Aug 24, 2007 | 06:47 PM
zx250's Avatar
zx250
OK, I guess I should have ask, did it stay normal after you let off and how much driving have you done since then? Take it out tonight and drive with all the lights and fans on and see if it comes back on.
Old Aug 24, 2007 | 07:00 PM
indebt's Avatar
indebt
it was only about 4mi on the freeway then 3/4 on surface streets, so no real telling when I start it to go home in 1hr I will see whats up
Old Aug 24, 2007 | 07:10 PM
John311t's Avatar
John311t
AHHHHHHH, what is going on, 3 bad alternator reports on this site in the last three days. I feel the pain!!!!
Old Aug 24, 2007 | 07:19 PM
Tenn01PSD350's Avatar
Tenn01PSD350
My vote is alt headed south too.
Old Aug 24, 2007 | 07:25 PM
Action4478's Avatar
Action4478
....x10....
