Battery light on and off???
Old Aug 24, 2007 | 06:02 PM
ALF1999's Avatar
ALF1999
Question Battery light on and off???
My battery light has been coming on and off for the last three months. I have had my alternator and both batteries checked. I have put about 6000 miles on it with no ill effects. Any ideas? thanks Alan
Old Aug 24, 2007 | 06:27 PM
zx250's Avatar
zx250
Of the next Riffraff East
Any certian conditions cause it to come on or go off?
Old Aug 24, 2007 | 06:28 PM
Action4478's Avatar
Action4478
I might take a close look at the wiring on the alternator ....Make sure everything is clean & tight & there are no broken wires..The wire can bereak inside the insulation, it may look good , but only works part time
Lastly maybe get a second opinion on the alternator.....
Old Aug 24, 2007 | 06:34 PM
zx250's Avatar
zx250
Does the light go off with higher rpm's and come on with lower? But yes, I could just be a bad connection some where.
Old Aug 24, 2007 | 07:49 PM
ALF1999's Avatar
ALF1999
There really is no pattern to the light coming on and off. I had the batteries checked again today and they were okay. I cleaned the posts and terminals. I will check the cables closely at both ends. Thanks Alan
Old Aug 24, 2007 | 07:52 PM
zx250's Avatar
zx250
If it does like mine did when it went out, it will start coming on more often, then start staying on longer at a time, then leave you stranded at work, ect. Took almost three weeks from the first time I noticed it, till it quit.
Old Aug 24, 2007 | 08:07 PM
Action4478's Avatar
Action4478
Mine gave me about 3 minutes...I was plowing.....
