What Defines a "HighBoy"?
Old Sep 16, 2013 | 06:05 PM
BruteFord's Avatar
BruteFord
I hear the term highboy all the time but have always wondered exactly what it means? Is it that they are taller stock, cause pretty much all solid axle 4WD Fords sit pretty high? So is saying you have a 4X4 Highboy redundant? Is it that it has a high pinion front axle, or that it's high steer? Or really none of it and just a term people throw around?
Really just curious to feed my personal curiosity.
Old Sep 16, 2013 | 06:24 PM
rogue40's Avatar
rogue40
The split between the 77 and the 77.5 4x4s. The early 77s had the divorced transfer case and sat a little higher than the post 77.5s.
In its pure form the term only refers to the 77s.
To say you have a 76 Highboy is redundant since all 76s had the divorced transfer cases.
Old Sep 16, 2013 | 06:31 PM
montana_highboy's Avatar
montana_highboy
If the rig has three driveshafts it's a highboy...two driveshafts it's a lowboy
Highboys sat approx. 4" taller than their 77.5-79 counterpart.
Old Sep 17, 2013 | 06:45 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
https://www.ford-trucks.com/forums/1...ease-read.html
post #8....
Old Sep 17, 2013 | 06:59 PM
rogue40's Avatar
rogue40
https://www.ford-trucks.com/forums/2...oy-sticky.html
Post #4
Originally Posted by OldThumper
The actual Ford highboy is a 32 Ford Model A fenderless car.
Old Sep 17, 2013 | 08:57 PM
riverguideguy's Avatar
riverguideguy
x2 if there is a short driveshaft between the t case and tranny its a hiboy
Old Sep 17, 2013 | 09:19 PM
paredneck33's Avatar
paredneck33
There is more than just the three drive shafts that define the highboy truck. There is also the front cross member under the front bumper. The frame width gets narrower after the cab. Also no highboy truck was available with a gas tank under the bed from the factory at all. Only the in cab tank. Some of the most common mods made to highboy trucks was the power steering. Some guys change the steering from the ram assist that is prone to leaking to the later crossover steering gear box from the 77.5 and newer 250's. And putting 1-2 gas tanks under the bed.
Old Sep 17, 2013 | 09:45 PM
1972RedNeck's Avatar
1972RedNeck
Says who? '67 -'77.5's have them, but '59 -'66's share all of the other characteristics.
Nope. It just doesn't get wider.
Old Sep 18, 2013 | 12:14 AM
lafermedavid's Avatar
lafermedavid
Highboy revisited
I think there is a skip in the record,Im not sure what it is,just glad I have one 1975 Highboy redundant
Old Sep 18, 2013 | 06:55 AM
704 dentside man's Avatar
704 dentside man
The link will tell you everything you could ever want to know...but the simplest answer of all is any 250 4x4 produced from 67-77.5 (before serial # Y20,001) is a highboy. It's an enthusiast term and those are the generally accepted years and cutoff. You can go on for days about the differences between a 76 and 79...but it doesn't matter, there were NOT 2 different 4x4 250's produced during 67-77.5 where one sat taller than the other. So to recap...if you have a 250 4x4 built between 67-77.5 (before Y20,001)...it's a highboy.
Old Sep 18, 2013 | 11:06 AM
bucks77ford's Avatar
bucks77ford
And the Highboy term refers to only the Regular Cab F250 4x4, not anything else even though others have used a divorced T case like the crewcabs I think. Either way though, this topic is always gonna come up and people with argue the term all day long about this and that and what their truck is and isn't.
RANGER589
May 19, 2010 04:14 PM
Wreckit87
May 18, 2010 08:43 PM
Henrys son
Aug 16, 2008 11:22 PM
rebocardo
Offroad & 4x4
Nov 13, 2006 04:09 PM
GeneStoner
Mar 17, 2005 10:53 AM
