Torque converter
Old Sep 15, 2013 | 01:28 PM
cory5517's Avatar
cory5517
Torque converter
What are the signs and symptoms of torque converter going out? 01 f250 cc 4x4 7.3
Old Sep 15, 2013 | 03:23 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
At idle it sounds like marbles in a coffee can. Or a steady leak out of the bellhousing. Or a slip error code. Or the front of the converter gets blued. Or the truck gets REALLY doggy off the line.
Old Sep 15, 2013 | 03:30 PM
cory5517's Avatar
cory5517
I have none of those symptoms but everybody says its my torque converter. My trucks shimmying at half throttle and can be felt in floorboard, pedal itself and rear of truck
Old Sep 15, 2013 | 09:00 PM
cory5517's Avatar
cory5517
On average what has everybody spent on rebuilding their trannys?
Old Sep 16, 2013 | 11:09 AM
Smokiesman's Avatar
Smokiesman
I don't know what "everybody" says! But I would be looking for possible other problems in your driveline! After that get a pro to check yer tranny!
Smokie
Old Sep 16, 2013 | 03:23 PM
Mark Kovalsky
Everybody doesn't know what they are talking about. Most likely it is the only part they know the name of, so that must be the problem.
You either have a problem with a ujoint, carrier bearing (if your truck has one) or a rear tire. It isn't the torque converter.
Old Sep 16, 2013 | 03:33 PM
Smokiesman's Avatar
Smokiesman
Thank you Mark!!
Smok
ie
Old Sep 16, 2013 | 03:56 PM
cory5517's Avatar
cory5517
Described my problem to a transmission mechanic and he said it sounds like a froze u-joint but is gonna drive my truck tomorrow to maybe rule out transmission. I just replaced the carrier bearing, tires and tps. I replaced ujoints about a year ago. Hopefully it's an easy and cheap fix
Jasonnoel
Apr 23, 2024 08:03 AM
shadow6777
Oct 22, 2015 04:29 AM
JOHN2001
Jun 11, 2012 05:55 PM
