Trans problem
Old Sep 15, 2013 | 06:53 AM
lew52's Avatar
lew52
Trans problem
Its a 2004 f 150 5.4 2 wd auto , i think is a 4r70w , when i first start out in the morning i get a trans malfunction on the dash and the od light flashes , if i shut the truck off and restart it goes away for the rest of the day , when it does this the speedometer dosn't work right , vss ?? any thoughts , thanks.....
Old Sep 15, 2013 | 07:13 AM
jk080's Avatar
jk080
Transmission Rebuilder
Sure it sounds like it could be a problem with the VSS because the speedo is malfunctioning, but you really won't know until you get the trouble codes.
Old Sep 15, 2013 | 07:21 AM
lew52's Avatar
lew52
I will get the codes , the check engine light is on , is the vss in the trans tail shaft or rear end ?? , want to have a look at the connector ....Thanks
mtntop1
Jan 7, 2018 08:00 AM
lew52
2004 - 2008 F150
Sep 16, 2013 11:54 AM
hey172
1978 - 1996 Big Bronco
Nov 11, 2012 11:34 PM
Bronk351
Jul 14, 2009 08:48 PM
spr1049nc03
Dec 31, 2008 07:38 AM
