c6 tail ends
Old Sep 15, 2013 | 10:01 AM
Huck4825's Avatar
Huck4825
c6 tail ends
Im doing a motor swap in a 76 f 150 custom.. taking out 351 mod with c6 trans auto and replacing it with 429 c6 auto.. My question is the mount of these are both different. Can I take tail end off the one and replace it with the other to mount up? Thanks
Old Sep 15, 2013 | 11:21 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes you can, if they are the same length. While you have the housing off think about replacing the bushing. A new one is about $5 at most auto parts stores. It would be far easier to do it now than to take it back out later.
Old Sep 15, 2013 | 11:28 AM
Huck4825's Avatar
Huck4825
Thanks for the fast reply. I'm about to pull motor and trans out. Guess you mean they should be same length tail ends.
I'll measure when I get it out.
Old Sep 15, 2013 | 12:40 PM
Mark Kovalsky
Yes, that's what I meant.
Old Sep 15, 2013 | 01:01 PM
Huck4825's Avatar
Huck4825
The 429 and trans out of tbird 72. The tail end is 17 1/4
The trans on the 351 is 13 1/2
They both same bolt patterns.
So I'm assuming they should bolt up to mount and drive shaft with out a hitch. I hope.
Old Sep 15, 2013 | 03:28 PM
Mark Kovalsky
So one extension housing is 17 1/4, and the other is 13 1/2? That will work fine, except that you won't be able to install the driveshaft because the output shaft will be sticking out of the housing by 3 3/4 inches. You won't need to replace the bushing, either, as the shaft won't be in contact with the housing.
If you want this to work you need to tear down both transmissions and swap the output shafts.
Old Sep 15, 2013 | 05:21 PM
Huck4825's Avatar
Huck4825
Thanks Mark.. I swaped the trans instead of tearing it all apart.. Now to shorten the driveshaft by 1.5 inches.. Thanks for your input..
Old Sep 15, 2013 | 10:10 PM
stuart1's Avatar
stuart1
You will have to shorten it more than 1.5".
Ak65F100
Sep 11, 2006 11:58 PM
td351w
Aug 17, 2004 08:44 PM
harddrive4x4
Mar 8, 2004 09:47 AM
Islandguy61
Mar 18, 2003 10:05 PM
BB
Jun 12, 2002 06:56 PM
