transmission help!!
Old Sep 13, 2013 | 10:22 PM
ruized94's Avatar
ruized94
transmission help!!
I rolled my 2002 2wd 7.3. It still run and drives but obviously body damage and frame damage. I want to buy a 2005 4x4 with half an engine and transmission. What im wondering is if i take the output shaft of the 5r110 and put it in the 4r100 will it work?
Old Sep 13, 2013 | 10:24 PM
ruized94's Avatar
ruized94
I am getting the 2005 4x4 fairly cheap so i feel this is my best option.
Old Sep 13, 2013 | 11:44 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
I don't understand what you want in the end. The 7.3 from the 02 into the 05 truck?
Old Sep 14, 2013 | 06:23 AM
Crewcab Turbo's Avatar
Crewcab Turbo
If you are saying you want to put the 7.3 with the 5r100 into the 05 it won't work. I have been told the bell housing bolt pattern it different. Also the 7.3 computer won't run the 5r100. I could be wrong but I'm sure someone else here will know more.
Old Sep 14, 2013 | 07:38 AM
ruized94's Avatar
ruized94
I want to put my 7.3 with 2wd transmission in a 2005 4x4. I now the output shafts are different so im wondering if I can swap the 5r110 output shaft in my 4r100. I have my wrecked 7.3 with everything to make the swap work I just don't know how to make my transmission line up with the t-case.
Old Sep 14, 2013 | 08:21 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
No, you can't swap output shafts. They are different diameter.
Old Sep 14, 2013 | 09:09 AM
ruized94's Avatar
ruized94
so what should i do? can i put a 4x4 output shaft from a 4r100?
Old Sep 14, 2013 | 10:01 AM
Mark Kovalsky
Yes, you can install a 4x4 shaft from a 4R100. I don't think it will fit the newer transfer case, but I don't know for sure.
Old Sep 14, 2013 | 08:18 PM
petrokiller's Avatar
petrokiller
Google a company called advance adapter. They are big in offroading world for engine/trans adapter swapping. Worth a call anyway.
Old Sep 14, 2013 | 11:31 PM
ruized94's Avatar
ruized94
would it be easier to swap it into a 2003 4x4 with a gas 5.4? like i said i have the whole truck so all the wiring is there in just concerned about lining everything into the transfer case.
superhooperduty
Jan 30, 2013 12:10 AM
jblakeman
Aug 1, 2012 11:03 AM
kennedy1
Dec 1, 2009 10:28 AM
nissandoc
20
Oct 20, 2008 06:00 PM
campman
Nov 16, 2004 07:03 AM
