Missing 7.3
Old Nov 15, 2004 | 02:49 PM
campman's Avatar
campman
Missing 7.3
Hope someone can shed some light on my dilema,I just traded my 2002 f350 cc drw sb 7.3 4.10 gears 4wd with 60 hp chip , for exactly the same truck for 2005.I pull a 14000# fith wheel And was hoping the stock 2005 would pull as good as the chiped 2002 , But so far have been very disapointed, the 2005 has no topend power . Am I missing something Or is this just the way it is.I have 2000 miles on new truck. I am sure missing the old 7.3 thanks for any wisdom
Old Nov 15, 2004 | 03:13 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
You do have a 6.0L engine in you 05 correct?
Old Nov 15, 2004 | 03:17 PM
campman's Avatar
campman
Yes Tim 6.0
Old Nov 15, 2004 | 04:10 PM
Maxium4x4's Avatar
Maxium4x4
As a previous 7.3 owner, I do not miss my 7.3L....just my 2 nickles worth. Maybe a visit to your dealer is in store, or pull your floor matt back from under your throttle.
Old Nov 15, 2004 | 05:08 PM
SBV45's Avatar
SBV45
Do you have adjustable pedals?
Old Nov 15, 2004 | 05:24 PM
campman's Avatar
campman
NO adjustable petals
Old Nov 15, 2004 | 05:28 PM
campman's Avatar
campman
The 2005 seems stronger from 0 to 60 ,then falls on face over that.It will not gain speed in overdrive on the slightest hill ,and seems to shift down twice on big hills while losing speed
Old Nov 15, 2004 | 05:30 PM
AGE mechanic's Avatar
AGE mechanic
Mine is much stronger that previous 7.3. On the top end too. Maybe it needs to see the service dept.
Old Nov 15, 2004 | 05:33 PM
drmdrvn's Avatar
drmdrvn
i think you are missing the extra torgue provided by the chip. the 6.0 is strong but it cannot compete with a 7.3 plus a couple hundred ft.lbs. an aftermarket tuner will probably fill your void and then some. but you must admit, the handling and turning radius are simply fantastic on the 2005. add a little more torque and i think you'll be a very happy camper.
good luck
Old Nov 15, 2004 | 05:35 PM
huntercgr's Avatar
huntercgr
While towing or not towing? If not towing, sounds like a definitive trip to the dealer because something is wrong.
Oh, and when you say overdrive, do you mean tow/haul?
Old Nov 15, 2004 | 05:43 PM
campman's Avatar
campman
Yes there some nice changes on the 2005 the brake control is awsome and the transmission is very smooth , Just wish it would stay in overdrive and pull hard. The chip only added 100 foot lbs and 60 hp making the two trucks very similar . Chipped 2002 310 hp 620 footlbs, 2005 325hp 570 ftlbs
Old Nov 15, 2004 | 05:45 PM
campman's Avatar
campman
Towing, huntercgr
Old Nov 15, 2004 | 06:14 PM
IB Tim's Avatar
IB Tim
Something here is a bit strange, it should just walk away from a 7.3....
Old Nov 15, 2004 | 06:19 PM
campman's Avatar
campman
Tim, that is what i was told before I traded ,I was just looking for some replys from people who had maybe owned both ,before I took it back to dealer
Old Nov 15, 2004 | 06:24 PM
IB Tim's Avatar
IB Tim
I think you might have a slightly sic one, now no worry it could be something very simple...I have towed next to 7.3 and the 6.0 just leaves them above 35mph...I pull a big trailer...see gallery...
