1978 - 1996 Big Bronco
Battery Cables ?
Old Sep 11, 2013 | 03:46 PM
harleydeen98258's Avatar
harleydeen98258
Battery Cables ?
Hello folks, this is probably simple, but I'm sure I'm over thinking it. On my 1993 Bronco I'm looking to replace my battery cables and looking at it I cant seem to figure out if I have to find some that look exactly like them or just buy some like what is on my '79. This is a completely stock Bronco so it has the positive cable that is totally new to me. I've searched on here to see what others might have done, but didn't find what I was looking for. Any help is appreciated.
Edit: I've looked into it further and found that both the pos. to switch and switch to starter run through the positive battery post. My question is do I have to buy a positive cable that is routed the same way or route them the tradition way, ie pos. to switch and then switch to starter?
Old Sep 11, 2013 | 07:15 PM
b4hntn's Avatar
b4hntn
I read it five times and I am not clear about your question.
Try this...Red Battery pos. to starter solenoid on the fender. Red Pos from other side of starter solenoid to starter.
Black Battery Neg (with pigtail going to fender ground) to frame to somewhere...I have never noticed where.
Old Sep 12, 2013 | 05:25 AM
b4hntn's Avatar
b4hntn
"Edit: I've looked into it further and found that both the pos. to switch and switch to starter run through the positive battery post."
I'm sorry, not enough coffee I guess. I just don't understand. Maybe someone will jump in here soon....
Old Sep 12, 2013 | 09:11 AM
Kemicalburns's Avatar
Kemicalburns
you can run a line from starter to battery and then another cable over to solenoid on fender. This is more or less what i plan to do on mine since the cable end on mine is shot. you can take the loom apart to see better how the cables are ran.
at one point someone over on FSB found a new replacment cable that is same as stock, they picked it up thru RockAuto. I have been unable to locate it myself due to lack of pictures of their products. If you do go about this take this time to upgrade your charge cable as well.
Old Sep 12, 2013 | 03:31 PM
harleydeen98258
Here is a photo of the OEM positive cable assembly that I'm trying to replace. These cables according to my local ford dealer are obsolete so I've been trying parts stores find a "replacement" for it...the parts stores seem to think I'm smoking something funny...
Old Sep 12, 2013 | 03:34 PM
Grubbworm's Avatar
Grubbworm
You may end up having to fabricate one yourself.
Old Sep 12, 2013 | 04:01 PM
gatorfor88's Avatar
gatorfor88
We have a company locally that makes new cables to your specs and needs. They arent very much more expensive than a generic off the shelf cable. Might be worth looking into seeing if you can do the same local.
Old Sep 12, 2013 | 04:32 PM
harleydeen98258
I had to run to our local salvage yard to see what you might be talking about...I think I'll do the same.
PotomacEd
Electrical Systems/Wiring
Jul 6, 2023 01:23 AM
jerryst
Jan 22, 2016 08:12 PM
Greenmillwork
Feb 22, 2009 04:56 PM
PotomacEd
Jul 25, 2006 01:36 PM
jhard527
Aug 5, 2004 12:34 PM
