Electrical Issues
Old Sep 11, 2013 | 10:38 AM
1SheldonW's Avatar
1SheldonW
Electrical Issues
I have a 73 f-250 changed out the starter, solenoid, ignition, tumblers, battery, battery cables, and when I go to shut truck off it still runs.
Old Sep 11, 2013 | 11:23 AM
mikeo0o0o0's Avatar
mikeo0o0o0
There has to be a back-feed from somewhere or a short between two wires.
You'll need to start doing some trouble shooting.
This is where a good set of wiring schematics and a multi-meter can be indispensable.
Old Sep 11, 2013 | 11:55 AM
fmc400's Avatar
fmc400
MSEE
Still runs as in how? As if you didn't touch the key, or it's dieseling?
Old Sep 12, 2013 | 12:08 PM
1SheldonW's Avatar
1SheldonW
doesn't diesel
1SheldonW's Avatar
1SheldonW
Originally Posted by 1SheldonW
doesn't diesel
like I didn't even touch the key
Old Sep 12, 2013 | 12:22 PM
fmc400's Avatar
fmc400
MSEE
All right then, following Mike's advice is about all you can do. You have to investigate.
Old Sep 12, 2013 | 10:34 PM
Scifi266's Avatar
Scifi266
Did you get any of the ignition wires swapped the wrong way? As in the ignition switch, it could also be a bad switch.
mrollings53
13
Aug 16, 2017 01:51 PM
forestgreen
May 4, 2015 01:16 PM
'70 ford f250
Mar 18, 2013 09:20 AM
JasoninOR
Sep 18, 2003 06:29 PM
