Sponsored by: Real Truck
restarting
Old Sep 10, 2013 | 10:08 AM
fgvanwhy's Avatar
fgvanwhy
restarting
Hey Guys
I haven't been on in a while ,but now I need some advise. I just replaced my manifolds with headers, because of broken studs. I removed the battery cables for the time I was doing the job. Now when I replaced the cables to check for any leaks it started .But when I turned it off to retighten the bolts it would not restart. The dash lights up but no starter. I reset the little button under the dash , but nothing. So last night I put the battery charger on for the night. Then this morning I tried it and it started I let it run about half hour to burn off header paint. Then same thing it would not restart. Any suggestions?
Thanks Frank
Old Sep 10, 2013 | 10:30 AM
bubbasz1's Avatar
bubbasz1
I would check the cleanliness of the battery connections, then the battery itself.
Old Sep 11, 2013 | 03:14 PM
fgvanwhy's Avatar
fgvanwhy
Restarting
Thanks for the reply. I did find the problem. When I removed the starter
I didn't think of a ground. I had to clean the starter and mounting surface
so I had a good ground. Now everything works fine. Lesson learned.
Tees77f150
15
Jun 27, 2022 04:53 PM
ssj7kids
20
Jun 3, 2011 12:13 AM
Fraalan
May 11, 2011 08:58 AM
quiacato
Mar 8, 2011 10:16 PM
Laddsmith
Jul 23, 2004 01:40 PM
