spark plug overheating
Old Sep 9, 2013 | 06:15 PM
mike L's Avatar
mike L
I used Champion plugs they show sign of over heating. Slightly melted electroids and a dark spot on the ceramic. Is this because it's not a oem plug. The plugs had the correct part number, I recheck with Champion. I also checked with other parts stores.
Old Sep 9, 2013 | 08:12 PM
Franklin2's Avatar
Franklin2
Check your timing. Is this the 93? There is a special procedure to check it if you do not know how. Have you pulled any codes? You might have a EGR problem which could cause this also.
Dresser77502
2004 - 2008 F150
Jul 29, 2020 06:09 PM
c96drumm
3.8 & 4.2L V6
May 1, 2011 12:50 AM
bbsitum
1997 - 2003 F150
Apr 23, 2011 05:18 PM
towmater
1983 - 2012 Ranger & B-Series
Apr 28, 2007 11:05 AM
