Code 172
Old Sep 8, 2013 | 07:09 PM
Ddaybc's Avatar
Ddaybc
Code 172
Hello all. I tested my truck today with a code reader and obtained code 172. My book says that's code HEGO (HO2S) Sensor fault/lean. I think that means my O2 sensor is sensing a lean condition. Is that correct?
I also think my O2 sensor is VERY old so I'm going to change it when I have the Catalytic Converter changed to a new one. I don't think either one has been changed since the truck was new.
Once I've changed the O2 sensor and the Cat I will test it again. I just want to confirm what the code means.
Thank you.
Old Sep 8, 2013 | 07:32 PM
timbersteel's Avatar
timbersteel
Yes, that's what my code book states as well.
Old Sep 8, 2013 | 08:57 PM
Ddaybc's Avatar
Ddaybc
K. Thank you Timbersteel
Old Oct 23, 2013 | 12:12 PM
Drivingmad44's Avatar
Drivingmad44
I'm getting the same code on my '95 F150 w/5.0L automatic.
So far I've changed the O2 sensor THREE TIMES, (first time was a Denso, second time was a Bosch, then I went with the Motorcraft one.) The code STILL comes back. I've also changed (ALL NEW PARTS), egr, egr tube, plennum gasket, vacuum canister (coffee can), egr vacuum solenoid, carbon vapor canister, purge valve, cap - rotor - plugs - wires, fuel filter, pcv valve. ALL the plastic vacuum lines have been replaced with rubber ones.
I've taken it to the exhaust shop and had it checked for leaks and NONE were found.
Could it be a dirty MAF?
I'm loosing my mind!!
What are the voltage specs for the O2 so I can check for bad wire harness?
Old Oct 23, 2013 | 12:17 PM
Drivingmad44
Forgot to mention, my truck runs great, no stumbling, no hesitation, no miss. Neither at start-up or when warm. Mt mpg isn't great put it's not terrible either.
When I restart the truck the check engine light goes off but comes back after a mile or two.
Old Oct 23, 2013 | 04:56 PM
Ddaybc's Avatar
Ddaybc
Drivingmad44, I don't know what the voltage specs are for the O2 sensor. However, in my research, I discovered that the wires to/from the O2 sensor have to be continuous. They cannot have any splices as that changes the resistance and thus the voltage being sent to the computer will be off. One can also have the O2 sensor wires routed too close to a heat source so the insulation gets damaged. I hope this information helps you.
My issue was traced to a split spark plug cap. I replaced it and my miss went away along with the codes.
Old Oct 23, 2013 | 06:49 PM
Drivingmad44
Yah, I changed the plug wires the other day, no change. The truck ran well before hand, runs better now but still getting the code.
Thanks for the input, I appreciate it.
fordtrucker
May 25, 2022 12:51 PM
tcarver20
Dec 16, 2014 12:28 AM
C Holmes
Jan 31, 2009 03:08 PM
84f250460
1997 - 2003 F150
Dec 2, 2006 10:10 PM
dmims
1997 - 2003 F150
Jun 1, 2005 07:07 PM
