Coolant purchase
Old Sep 9, 2013 | 04:37 PM
sdetweil's Avatar
sdetweil
Originally Posted by SultanGris
why would you need to carry coolant around with you for a new truck? do they leak or use it somehow? sounds like a serious issue to me. I would expect to never have to add coolant to mine anytime between new and the recommended flush date unless a hose broke or something.
this is a 'new to me' new vehicle, still under warranty. the vehicle requires coolant that is not on every shelf.
The diesels, we always try to keep an eye on things, and the degas bottle is one of those. It was down an inch cold.. how long, why, .. I don't know.
why carry it? why not.. no point leaving it at home for 3000 miles.
I expect not to use it.. I only checked my 08 drw once in 40,000 miles, similar just before a towing drive to Chicago. it was fine. (also bought used).
(Also bought 2 bottles of PM22 fuel additive).
Old Sep 9, 2013 | 04:39 PM
sdetweil's Avatar
sdetweil
Originally Posted by senix
Sam that is cheaper than the ford gold coolant @ 17 bucks a bottle if I recall.
Let me know if you swing by Maryland...(kind of out of the way).
this WAS the Ford Gold, red bottle. bought at the dealer partts counter.
the list price was 19.99.. no idea why he gave it to me at 12.80.
PM22 at 8.99.
Old Sep 9, 2013 | 04:44 PM
SultanGris's Avatar
SultanGris
Fair enough. Im new to diesels also, got 1000 miles on mine, figured you had a good reason and i wanted to hear it and learn something. Ive never seen coolant level fluctuate enough on a gas motor to the point you would be compelled to add some so I had to ask! . Your explanation makes perfect sense to me. If its hard to find I can see the desire to keep some at home and take it on a long trip also if I thought there was a possibility you would need some.
What does that fuel additive do? you use it every tankful? Sorry to ask so many dumb questions but I might as well pick up a few pointers from the experts!
Old Sep 9, 2013 | 04:55 PM
sdetweil's Avatar
sdetweil
I am far from an expert. just above baby stage here compared to most of the folks.
Rumor has it that the Ford Cetane additive will help with mileage. I am driving my dually 3000 miles.. so 1 mpg is a decent gain. we'll see..
my 2008 got 9 towing 7000lbs and 11 around town empty. the 2012 looks like 14-15 empty (15.6 on the lom) and maybe 10.5-11 towing (13,000 lbs). Illinois heavy biodiesel.. so a Cetane additive will be helpful. our schedule has changed and I think I get to miss Illinois all together this trip.
they say it can't hurt. glad I have the dually for towing and stability.. wish I had the 3.31 gears for mileage. my 2012 250 got 18+ on the highway at 75-80.
Old Sep 9, 2013 | 05:20 PM
03 SVT VERT's Avatar
03 SVT VERT
I don't know about other people, but I always carry some spare fluids on board (along with other tools, gear, simple spare parts like bulbs, and so on).
From years of driving commercial trucks I'm used to doing a pre-trip inspection. Which, is a good idea, even on private trucks. Especially in my state, since all diesel trucks between 10k and 18k GVWR are considered self-inspected.
You walk around, check your fluids, tires, and so on. If your coolant is a little low (you do loose some over time from evaporation, pumping frictions, and coolant oxidation) you can add some. If your oil gets a little low, you can add some. It's all part of basic maintenance and vehicle care. Remember, federal and state laws say that you, as the driver, are responsible for ensuring your vehicle is mechanically sound and in peak operating condition.
Plus, like you mentioned, it's also good to have on board in case an issue does arise (like a blown hose, cracked radiator, whatever). Today's trucks aren't like those of the past where you could refill the radiator with river water with no worries.
Old Sep 9, 2013 | 05:25 PM
03 SVT VERT
PM22 at 8.99.
It should have been the Ford Orange. For your sake I hope it wasn't Ford Gold, since that's not compatible with the Ford orange in the 6.7L (both come in a red bottle). If it's Ford Gold than you just contaminated the system with nitrates.
Old Sep 9, 2013 | 05:36 PM
SultanGris's Avatar
SultanGris
I totally understand, and I always did too back when I drove 10+ year old vehicles that were always breaking down. Could practically rebuild it on the side of the road with all the crap I used to haul around, lol! Just thought it was a little odd that someone with a 6.7 that can only be 3 years old max would be worried about having coolant on board. Since Ive started owning new vehicles Ive found no need to carry all that stuff anymore because they dont break down or leak fluids. The only thing you should really need for a 5 year old or newer vehicle is the ability to change a tire. I used to check the gas and fill the oil on some of my previous rides, haha!
Old Sep 9, 2013 | 06:03 PM
sdetweil's Avatar
sdetweil
Yes, my fault. The bottle does say Orange.
Old Sep 9, 2013 | 09:11 PM
Jus2shy's Avatar
Jus2shy
System occasionally need to burp and such given the ambient temperature at the time of manufacture versus where it is at present. That's why the degas bottle has a full fill that is roughly midway on the bottle. It's designed to allow some fluid back in there, but at times the system can take-in even more fluid than was filled at the factory. So a little extra fluid may be needed. Typically after that you don't really need to add anymore fluid. I only added a tiny bit to my F-150 to put it at the full mark and I never added anymore again.
Old Sep 10, 2013 | 05:06 AM
senix's Avatar
senix
I occasionally added a bit to my 6.4 over the years. Not due to a leak but I truly believed due to the hot temps under the hood from heavy towing.
My oil analysis always came back just fine.
I would not be surprised if there is some seasonal changes here as well due to temp variations.
Resendiz
Nov 30, 2017 02:03 PM
Resendiz
41
Oct 21, 2016 12:46 AM
Padlock
Nov 11, 2014 06:42 PM
BuckHammer
22
Feb 29, 2012 05:39 PM
calf roper
20
Jul 2, 2009 10:15 PM
