Alterstart alternator
Old Sep 7, 2013 | 11:05 PM
buttwheat's Avatar
buttwheat
Ok so I think I have been convinced to do a 3g switch. I do not want to get it from a junk yard you can if you want but I just don't want to.
What do you guys think of this one? Click Me
Old Sep 7, 2013 | 11:23 PM
Scifi266's Avatar
Scifi266
Looks decent, what are you running in your truck currently? I've read some of the conversion threads and they had to clock the housing so that it would fit better in the bracket. 160 amps seems a little excessive unless you are running a decent amount of add on's or a big sound system. Have you checked your local part houses? you might get a better deal.
Old Sep 7, 2013 | 11:35 PM
buttwheat's Avatar
buttwheat
I'm running the stock 60 amp alternator. I also thought that 160amps was a bit excessive but a talked to the Alterstart guy and he said: "This one will supply amperage only as needed. It has a great low end capability. Idle output capability is double the 1g you have now. The 3G has extra heavy duty electronics for extreme use. So, when used with a light load. It will be on coast and will live for years."
I have a camper special with dual batteries and have a deep cycle on the camper side which I use for my camper and the 60 amp one isn't cutting it. This one does 75amps at a 800rpm idle
Old Sep 8, 2013 | 08:07 AM
Blue and White's Avatar
Blue and White
Looks good. I've priced premium reman 3g ('92 Taurus from memory) and they are more expensive than that new one.
Old Sep 8, 2013 | 12:09 PM
Scifi266's Avatar
Scifi266
Sounds like it would match your setup with the camper. Have you found any other reviews on that alt?
Old Sep 8, 2013 | 05:50 PM
V10man's Avatar
V10man
It looks like a nice alt and on the plus side it comes with the pully and wiring. My son just ordered one from these folks for his 96 F250. RJM Injection Tech — Alternators He is running several high amp stereo amps and this one is working great. No more pulsing lights at idle. He told me that the tech he talked with at RJM said he'd have 100a at idle. Also mentioned that when you start reaching max output, the single belt can barely turn anything over 160A. I am thinking of going that route also. For a comparison, Rockauto has NEW a/c delco 3g 130a alts for $135.
Old Sep 8, 2013 | 06:00 PM
psychlopath's Avatar
psychlopath
I'm a fan of the above mentioned RJM unit. It's brand new and I've never had anything bad from that guy.
You can get a 200 amp unit as well.
ANY alternator will only put out as much amperage as required by your system. Having the seller point that out as a selling point makes me think that if I were in your situation, I'd spend money elsewhere.
Old Sep 8, 2013 | 10:25 PM
buttwheat's Avatar
buttwheat
I did a google search and most everything was positive, They have a 100% rating on ebay but most people give their feedback right away so that doesn't say much.
I don't see that as a bad thing he was trying to educate me or am I missing something?
Thanks for the info looks like there are many choices
Thank you everyone this place is great for getting answers
Old Sep 8, 2013 | 11:39 PM
veetwelve's Avatar
veetwelve
Times Two on the RJM products... same 160-amp alternator for only $150. And to reiterate what's already been pointed out, once you get near 100 amps with a single belt, that thing's gonna squeal like a pig. It usually occurs at start-up, and it's pretty tough on belt longevity. Good luck, and let us know what you wind up with.
Karl
akblackfoot
Nov 26, 2016 01:53 PM
tbruz
Nov 11, 2015 06:27 PM
ac700wildcat
39
Dec 16, 2010 02:48 AM
berry1234
Mar 26, 2009 07:13 PM
meck1
Jul 3, 2003 11:14 PM
