1966 - 1977 Early Broncos
73 new owner
Old Sep 6, 2013 | 01:40 PM
RSCHAP1's Avatar
RSCHAP1
73 new owner
Pretty used to and have owned quite a few full size, but my first "lil" one.
Manual steering, manual drum brakes (which need work).
351 with a mild build, c-4 with stall convertor and shift kit, 4.56s spool in the rear, limited slip front. Old 35" Gumbo Mudders Actually cannot believe they look as nice and solid as they do. No weather check or cracks!
Owned it a few weeks now and am starting to wonder about upgrades I had always looked for when shopping...
the steering and brakes.
Can anything from 78-79s been used?
What's best?? I mean cheap w/o being junk or a month's work of fabricating to get to work
Also, it had a full soft top at one time, now just the rails on top of the tb and a couple brackets...
Anyplace to look or anyplace to get soft top and doors w/o breaking the bank???
All I have is a bikini now, may be able to get the original hard top from previous owner. Sounds like it has been stored outside for a long time though
Appreciate any help and/or advice !!! Thanks
Old Sep 6, 2013 | 01:47 PM
Grubbworm's Avatar
Grubbworm
That looks like a sweet deal. I'd love to have one of those myself. Where did you find that one?
Old Sep 6, 2013 | 01:51 PM
RSCHAP1's Avatar
RSCHAP1
CL
Local CraigsList
It shows a little better in the pics than actually seeing it in person.
Last 22 years it was strictly an off roader, mud, and sand dune truck.
Paint is 22 years old.
I actually have done a liittle to it and have it re-listed with new ads.
Deciding if I want to do the upgrades or sell and start shopping all over again.
Thanks
Old Sep 6, 2013 | 01:55 PM
Grubbworm's Avatar
Grubbworm
Originally Posted by RSCHAP1
Local CraigsList
Thanks
How much and where do you live? Good Buddy.
Old Sep 6, 2013 | 01:56 PM
RSCHAP1's Avatar
RSCHAP1
I have it listed for $11 thousand in the ads.
I am in Lowell MI a little ways from Grand Rapids area.
Old Sep 6, 2013 | 02:05 PM
Grubbworm's Avatar
Grubbworm
I have it listed for $11 in the ads.
I would take it for that price. maybe if you were a little closer.
Old Sep 7, 2013 | 06:45 PM
chrlsful's Avatar
chrlsful
if U have:
of course all the drive line;
the tilt steering wheel from the FSB;
&/or
U could make "1 tuns" with it's axles/knuckles (frnt & rear).
My man (McF) in Chesapeake, VA has 1 w/a 400ci from that era...
"...any help..."
JBroncoGrvyrd is right there (in yer geographic area), has The premier EB web site - cb dot com.
Got my 1/2 cab (top) from him for 250 $ in '83.
Old Sep 17, 2013 | 12:30 PM
RSCHAP1's Avatar
RSCHAP1
I guess I will try to be little more specific and see what I can figure out...
Will full size spindles, bearings, rotors, calipers, mounts, and lock outs fit??
Early 70s thru 1979?
How about the IFS stuff? 1980-1996?
Would disc brakes work from an IFS donor truck?
I see how the master cylinder on a little Bronco's firewall is on an angled mount?
Is the master cylinder and vacuum booster same as a F150 just placed on the angled bracket? Or smaller diameter too?
Again,any certain years?
Best to buy a new bracket? I imagine hard to find used...or any other applications.
And ... the power steering??
Pump and gear box from a full size Bronco or F150 work? 70s through 90s??
Guessing I would need a specific bracket/mount for the pump too?
Lastly, I have seen a few tilt wheel steering columns for big Broncos and 78-79 F 150s listed locally. Any interchange to my 73 Bronco there??
VERY much appreciate all the help.
Thinking more about refreshing this over the winter.
Maybe add a "family" style cage and or something custom to hang a 3rd row out over the tailgate even.
Not sure right now, but sand dunes are looking like fun to the family next summer.
THANKS ! ! !
Right now I do know for sure that I will be cleaning a few things up.
The turn signal switch in the column needs replacing. Gotta see why wipers, heater blower motor, and a few other odds and ends are not working.
The pads/gaskets under the front turn signals look rotted. I see the swap/conversion to the smaller earlier ones, may do that or just get new pads soon.
I would also like to get rid of the Edelbrock valve covers and air cleaner
They look nice enough, but I would like to just do a chrome lid with a 351 sticker to look more original and blue factory style valve covers.
Old Sep 17, 2013 | 05:56 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Old Sep 18, 2013 | 03:44 AM
RSCHAP1's Avatar
RSCHAP1
Saw a co-worker's 66 or 67 last night.
That truck had a power brake set up that looked like it was run off the power steering pump...
I had never seen anything like that before, anyone familiar with that set up??
THANKS for ll the links 77&79F250 !!!
That will keep me busy for a while
Old Sep 18, 2013 | 05:18 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Hydroboost. Ford Bronco Brake Upgrade - Technical Articles - 4 Wheel Drive and Sport Utility Magazine
Old Sep 18, 2013 | 05:48 AM
RSCHAP1's Avatar
RSCHAP1
Tht looks just like what I saw
Thanks or that too!
Looked at Summit and CPP w/o finding a price.
Is it comparably priced to doing a vaccuum factory style set up...?
Old Sep 18, 2013 | 06:29 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
It's much better than a vacuum setup and can be sourced from a local junk yard. Astro van is the most common one used I know of. Pile of links: Google
Old Sep 18, 2013 | 06:42 AM
RSCHAP1's Avatar
RSCHAP1
No kidding...
my brother, who calld last night wantig to hit the dunes with his sand rail and my Bronco...also has and AWD Astro with a bad motor.
Maybe I will take a look under his hood.
Thanks for that too!!
Old Sep 21, 2013 | 10:53 AM
chrlsful's Avatar
chrlsful
"...brake set up that looked like it was run off the power steering pump..."
Try'n JY source that as well (unless yer rich) cuz I C them listed for close to $300.
8^0
northerndave
112
Sep 16, 2020 08:07 AM
petermorey
Jul 27, 2017 11:53 PM
troxy
29
Aug 12, 2016 11:15 PM
dsrtjeeper
25
Dec 15, 2013 12:34 PM
BishopRyan
15
May 15, 2008 08:21 AM
