I have a 2001 f250 sd 4x4. For the past year it will blow cold air unless I'm in stop and go traffic then it blows warm air. Engin temp thermostat and water pump are fine. Yesterday it quit blowing all together and it really wouldn't bother me but where I live the morning temps and rainy days are causing the windshield to fog up and my defroster not even working. Where can I start to get this fixed
The clutch is kicking in and out but no air what so ever is coming out on any setting. I haven't tested it yet its more in likely a a few things all to gather gonna start with a new relay fuse tomorrow and double check the clutch spacing and vacuum lines. I'm pretty sure it has plenty of coolant too. Thanks for the help
Sorry, If you were closer to me... There is a place near me that is really good with A/C's. Ironically, it's called Marietta Radiator. Good luck with yours.
