Drive shaft issue question...
Old Sep 5, 2013 | 12:38 PM
BrotherMabe's Avatar
BrotherMabe
I lowered my F100 5-6" in the rear and changed rear ends from a Ford 9" to a Dana 44.
Now my drive shaft seems to be too long?
This is a 3-speed manual transmission truck.
Any thoughts or advice?
Last edited by BrotherMabe; Sep 5, 2013 at 04:00 PM. Reason: Now the drive shaft is stuck in the manual transmission!
Old Sep 5, 2013 | 01:08 PM
JEFFFAFA's Avatar
JEFFFAFA
Makes sense to me. Call your local driveshaft company to double check me. Or a fellow FTE er will chime in. If I were to measure it I would put slip yoke about 3/4 the way in the tranny and measure the driveshaft center of u-joint cap to center of the opposite u-joint cap.
Old Sep 5, 2013 | 08:43 PM
CougarJohn's Avatar
CougarJohn
Make your measurement as Jefa suggests. Take the driveshaft you have along with your measurement to a suspension or rear-end shop, have it cut, shortened to the proper dimension, rewelded. Maybe get the u-joints replaced for drill.
Semper Fi
Old Sep 6, 2013 | 12:09 AM
lizardman1's Avatar
lizardman1
Lower the truck and change the diff???
Old Sep 6, 2013 | 04:54 PM
CougarJohn's Avatar
CougarJohn
Yes, Lizard, I am scratching my head also.
Brother, you have severely distorted the geometry that the Ford engineers put in your driveline. The level of the rear-end goesoutta should match the level at the transmission goesinta. If they do not match, your driveshaft will "skip rope" which means imbalance and the transmission spline slipping in and out to accomodade the mismatch. Even if you cut and fit a new driveshaft you will probably have severe vibrations at highway speeds.
My advice is to get the thing to a rear-end shop, let them adjust the angles of attack on the driveline, cut and reweld the driveshaft.
Old Sep 6, 2013 | 05:30 PM
BrotherMabe
Great knowledge!
Going with what Jeff advised first.
Not quite ready to relocate the perches just yet, Cougar...
However, if this doesn't work I will try that next!
Thanks!
Old Sep 7, 2013 | 03:22 PM
JEFFFAFA's Avatar
JEFFFAFA
Thanks!
I believe you can get some thin tapered spacers for at the spring pads to change your pinion angle.
Old Sep 7, 2013 | 05:56 PM
BrotherMabe
Yes! That sounds like a super easier way to change the angle!
I know it may have seemed like a crazy idea to change the entire rear-end, but I came across this Dana 44 at a bargain. ($120)
It is super clean and it came out of a '66 F100, plus it already had a posi-unit, and a 3.54 gear, which is two of the upgrades I was looking for, so I just couldn't pass it up!
I am scheduled to pick up the drive shaft no later than Tuesday of next week.
I hope it will work out.
I will keep you updated.
Here's a few pics:
i1353.photobucket.com/albums/q674/BrotherMabe/null_zps03953774.jpg
i1353.photobucket.com/albums/q674/BrotherMabe/390-32_zpsa394bb29.jpg
Old Sep 7, 2013 | 06:07 PM
BrotherMabe
A few pics
Old Sep 9, 2013 | 11:32 AM
JEFFFAFA's Avatar
JEFFFAFA
I got an adrenaline rush after those two pics there buddy! Phew!
Old Sep 10, 2013 | 08:22 PM
BrotherMabe
Hopeful...
I am putting the shortened drive shaft in soon.
I am hoping that the pinion angle is ok.
If not, I did find a machine shop that makes the shims for the perches on the Dana 44.
Im excited about getting everything put back to see how it works.
Ill keep everyone updated...
One more pic here:
Old Sep 10, 2013 | 08:51 PM
BobbyFord's Avatar
BobbyFord
I lowered my short bed 5-3/4" in the rear. My driveshaft was just a taste too long after the lowering mod. I kept the stock driveshaft and had a brand new driveshaft built in case I want to return my truck to stock height. I always tell people to measure the pinion angle prior to any rear suspension mods. 4-5 degrees upward should be good. The pinion angle should mirror the driveline angle.
MightyThor
Jul 31, 2017 02:06 PM
52' fordnut
Sep 13, 2012 09:19 AM
finneys98xj
May 11, 2011 02:17 AM
custom cabby
Apr 7, 2008 11:02 AM
tonydlt
Mar 11, 2007 09:39 AM
