quick glow plug question
Old Sep 4, 2013 | 11:10 PM
ranagent's Avatar
ranagent
I just bought a 1990 f-350 with 7.3 It starts hard first time every day. All of the glow plugs show .2 - .3 resistance, so I have new motorcrafts on the way.
The relay is underneath the air cleaner and appears to be working correctly. There is the on/off clicking from it for a little while. I think the controller is bad though as I show power across the relay for at least several minutes. Is it bad for sure, or is it doing this because it senses the bad plugs? I have no power to the plugs, actually it flashes about 4.5 volts.
Thanks
Old Sep 7, 2013 | 08:18 AM
Chevy_Eater's Avatar
Chevy_Eater
If you're getting power across the relay you should be getting power at the GPs. I'd check the connections of the GP harness at the relay itself.
However I'd be concerned if it has power for several minutes, you will kill your GPs if you do not address that first. The controller is supposed to turn the relay on for 15+/- seconds. That newer style cycles faster if there is two or more burned up GPs.
Glow Plugs 101 Tutorial
Old Sep 7, 2013 | 10:18 AM
ranagent's Avatar
ranagent
Yeah I found my test light and 6 test bad. I've pulled 2 of the bad while I wait for new motorcrafts and even though they are autolites they came right out.
Ravenous Weasel
Jan 17, 2012 08:30 AM
garyh8
Jan 14, 2012 11:25 AM
Cus Bus
May 5, 2008 12:41 AM
builder9497
Mar 16, 2008 07:56 PM
