93 7.3 glow plug relay
Old Jan 8, 2012 | 07:41 AM
garyh8's Avatar
garyh8
93 7.3 had strange set of happenings. Tee plastic cover that protects the relay came off this caused throttle cable to ground the white wire on relay causing relay to engage and i guess burned out relay and glow plugs. With key on 12v on input side and11.6 on load side even with white wire disconnected. Any thoughts on how to determine extent of damage.. Thanks
Old Jan 13, 2012 | 08:26 AM
my1strealtruck's Avatar
my1strealtruck
I would replace the controller 1st. Beat I found was on ebay.You can test each glow in the motor to see if they burnt out. I would replace them anyway. Make sure and use the right ones.
Old Jan 13, 2012 | 04:55 PM
BomerFett's Avatar
BomerFett
Does the relay relay still turn off and on in a normal cycle?
Old Jan 14, 2012 | 07:27 AM
my1strealtruck
Yes. I would check the temp sensor for the glow plugs. I would unplug it the glow plugs relay should not be letting power through. If is still letting power through bad relay stuck closed.
Old Jan 14, 2012 | 11:25 AM
84-6.9L's Avatar
84-6.9L
If it is just the relay, go to the parts store and get a relay for an 86 350 with a 6.9. In the case of the 7.3 they sell the relay with the controller for big money. the relay I suggested is the exact one you have so you can replace just the relay if you need to, its ALOT cheaper
Dashriprock1977
84
Feb 1, 2017 08:41 PM
Ravenous Weasel
Jan 17, 2012 08:30 AM
Stroker Ace
Mar 25, 2011 06:53 PM
Big Swole
Jan 16, 2008 06:56 PM
BOBSDIESEL
Oct 21, 2005 01:58 PM
