Truck stalls while a/c is running
I just got the a/c in my 94 with a 5.0 running not too long ago. At first everything was fine but a day or two later every time I turned the ac on the rpm would drop and not come back up and the engine would stall if I stopped while backing out of a parking spot. It only got worse over the next couple days to the point of stalling when I changed gears. As soon as the clutch was disengaged that was it. It almost caused a bad accident one time. I had the alternator tested and that turned out to be bad so I replaced it and it runs better but not great. The rpm still drops when the ac comes on and it still stalls every now and then when the engine is cold but not nearly as bad as before. What could be causing the low idle and stalling? Is it something electrical like a relay or sensor? Or could it be something wrong in the ac system itself?
I picked up a new IAC and I'll get that put on ASAP. Even the guy at autozone said that could be the issue. The truck doesn't stall at idle but it does drop from about 650-700 RPM to 500 or less when the ac comes on. I replaced just about everything in the ac system so unless I just got a bad part from the factory, I doubt that's the issue. And the TPS was replaced not too long ago. Hopefully this will do the trick.
