Trying to pick some brains
Old Sep 4, 2013 | 12:52 PM
Strokednstroken's Avatar
Strokednstroken
I'm new to this online wrenching tips but it seems usefull.
I have a 97 powerstroke manual 5 speed 218000 miles on her. Edge cts, downpipe to 4 inch, fpr shim, dyi filter, have the fuel filter houseing unrestriceted, both bank fuel bolts drilled out, dyi high idle. The truck runs great down the road but acceleration is where I notice it studder don't build much boost I do need to replace my up pipes they do leak, sometimes when I let off the clutch it will almost die but then just as fast it comes back up to idle... Any suggestions???
Old Sep 4, 2013 | 02:52 PM
fordpride's Avatar
fordpride
Welcome to FTE !
Stop watching the powerstroke help guy. He know just enough to help you destroy your engine.
If the uppipes are in good shape you can just change the gaskets.
Old Sep 4, 2013 | 03:14 PM
madpogue's Avatar
madpogue
Pre-turbo exhaust leak --> low boost --> acceleration issue(s). Fix what you know is wrong, then see what happens.
Old Sep 5, 2013 | 09:11 AM
Midwest Dually's Avatar
Midwest Dually
Originally Posted by fordpride
Welcome to FTE !
^^^ Second that to all the above!
Old Sep 6, 2013 | 01:27 PM
Strokednstroken
I was told not to reuse the pipes because its more or less a gasket that is built onto the up pipe. Did disconnect the icp sensor and noticed no diff in engine.
Old Sep 6, 2013 | 01:47 PM
rideracelivemx7's Avatar
rideracelivemx7
I noticed you said it did stutter, a stutter is usually HPO related. Do a free rev in park, mash the throttle and let us know if it pops around 23-2500 RPM. if so then you need new injector orings. I have seen plenty of trucks grenade the oil rings at low and high mileage.
Old Sep 6, 2013 | 02:32 PM
Strokednstroken
Hpop is fine. It's not so much a stutter as it is almost like a carb flooding out. If I ease into the pedal it doesn't do it but a quick mash to accelorate when not rapped is when it occurs. Like I said the pre turbo leak is a prob but was wondering if there could be something else. When I fix the turbo here shortly I'm gonna just go ahead and replace the fpr,&icp, and also clean filter housing and fix the typical leak or should I put a banjo block in it?
What is ur opinion on stage one injectors. Was gonna put a one inch houseing on it but I might just go with alil bigger injectors. It's not a race truck I just want a great puller.... Suggestions ???
Old Sep 6, 2013 | 11:02 PM
fordpride's Avatar
fordpride
Are you sure you are not just feeling turbo lag ?
These turbos do start spoolin till around 2k rpm's
Old Sep 7, 2013 | 07:12 AM
DIYMechanic's Avatar
DIYMechanic
What exactly do you mean when you say that the fuel filter housin is "unrestricted"? Have you checked the fuel pressure at the regulator?
And I would second the recommendation that you should try a free rev in neutral and see if it stutters around 2300 RPM. It doesn't mean that the HPOP is bad, just that you may be losing some oil past a few blown o-rings on the injectors.
Old Sep 7, 2013 | 08:50 AM
Strokednstroken
I guess I should have made comment the fact that I know these engines very well I'm not a rookie mechanic by any means I have home tested everything that I can. That being said never in my life have I experienced a turbo going bad in a truck of mine and am pretty sure that could be happening I made a home made boost gauge 7 lbs is it I know I have a leak but that much? Unless there is a massive one behind the motor that I cannot see
Old Sep 7, 2013 | 10:23 AM
fordpride's Avatar
fordpride
Nate I'm pretty sure he gutted the stand pipe.
Old Sep 7, 2013 | 10:25 AM
fordpride's Avatar
fordpride
Have you tried unplugging the MAP sensor and taking it for a ride ?
Old Sep 7, 2013 | 10:54 AM
DIYMechanic
Gotcha. I would still check the MAP and fuel pressure and yeah, if the leak is a substantial one, I could see the turbo maxing out at 7 PSI. Worse come to worse, pull the intake off of it and give the turbo shaft a wiggle. If the turbo is gone you'll have lots of endplay.
Old Sep 7, 2013 | 04:38 PM
427 fordman's Avatar
427 fordman
I agree with Nate. If the leak is very bad at all you could be losing that much boost. Stock is only about double that.
GridLine
6.7L Power Stroke Diesel
19
Nov 13, 2014 08:53 AM
Zeropowerstroke99
42
Nov 4, 2013 06:49 AM
Jbrown8988
15
Mar 25, 2009 08:47 PM
robs01f250
Feb 3, 2008 05:54 PM
putzhall3
May 15, 2007 01:34 PM
