Instrument panel
Old Sep 10, 2013 | 02:53 PM
JEFFFAFA's Avatar
JEFFFAFA
D1TZ10K843B.......With lamps:
Dennis Carpenter Ford.....704-786-8139
Wesley Obsolete Parts.....606-787-8139
NOS Parts Ltd................972-937-2201
Old Sep 10, 2013 | 03:00 PM
aidandj's Avatar
aidandj
Originally Posted by aidandj
I need the one for the guages
Brain fart...I need the one for the warning lamps
Old Sep 10, 2013 | 03:07 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by JEFFFAFA
D1TZ10K843B.......With Oil/Amp warning lamps:
Dennis Carpenter NOS Obsolete Parts in Concord NC has ONE: 704-786-8139 / 800-476-9653.
Wesley Obsolete Parts in Liberty KY has ONE: 606-787-5293.
NOS Parts Ltd in Waxahachie TX has FIVE: 972-937-2201.
GRIESEL MOTOR CO. in Okarche OK has ONE = 405-263-7242.
CROSSETT FORD-LINCOLN in Crossett AR has ONE = 870-364-2162.
Jeff: "Go see Cal" Worthington died last Sunday.
Old Sep 10, 2013 | 03:18 PM
aidandj's Avatar
aidandj
150$ Ouch, not worth it for an oil lamp. I guess off the the junkyards it is. Which years are interchangeable? Just 71 and 72?
Old Sep 10, 2013 | 03:19 PM
Area351's Avatar
Area351
Did you find any?
Nope sorry.
All the ones I have are 67-69 and they don't have that circuit film.
Old Sep 10, 2013 | 03:27 PM
NumberDummy
$150 Ouch, not worth it for an oil lamp. I guess off the the junkyards it is. Which years are interchangeable? Just 71 and 72?
See post 18: There are 9 of these available from 5 sources, so how many sources did you call?
D1TZ-10K843-B .. Printed Circuit Board-Use with Oil/Amp WARNING LAMPS / Obsolete
Applications: 1971/72 F100/350 & 1971/74 E100/300 (Econoline).
Old Sep 10, 2013 | 03:46 PM
JEFFFAFA's Avatar
JEFFFAFA
Jeff: "Go see Cal" Worthington died last Sunday.[/quote]
You mean no more Brock-a-brella hats?
Old Sep 10, 2013 | 03:55 PM
aidandj's Avatar
aidandj
I just checked one, I assumed the others would be similar prices.
Old Sep 10, 2013 | 04:36 PM
NumberDummy
Qwist on a bicycle, call them all! Obsolete parts prices vary wildly from one source to another.
Usually the dealers are cheaper than the obsolete parts vendors, cuz they're STUCK with the parts, as they cannot be returned to FoMoCo for credit.
Griesel in OK and Crossett in AR are dealers. Carpenter NOS Obsolete, Wesley and NOS Parts LTD are obsolete parts vendors, make their living selling these parts.
Old Sep 10, 2013 | 04:37 PM
aidandj's Avatar
aidandj
Qwist on a bicycle, call them all! Obsolete prices vary wildly from one source to another.
Thanks for the heads up! I didn't know that.
Old Sep 10, 2013 | 09:55 PM
70-360fe's Avatar
70-360fe
Not sure how bad your circuit board is but I have repaired opens on other clusters. I'am assume ford is the same with copper traces under the membrane.
You will need to get a wiring diagram, ohm meter, soldering gun, solder and small stranded copper wire. (Like phone cable wire). Check your board according to diagram using your meter. When you find an open scrape the plastic off both the of the open ends to expose the copper trace. Solder in a jumper wire to close the opening. You can use electrical tape or rubber cement glue to hold down wire if it's a long run.
moneymike
Escape & Escape Hybrid
Dec 9, 2017 10:51 PM
BruteFord
Feb 25, 2014 01:51 AM
WhiteRanger8384
1983 - 2012 Ranger & B-Series
Nov 25, 2009 06:40 PM
Scifi266
Apr 10, 2007 09:46 PM
ya sure
Feb 23, 2003 02:02 PM
