Instrument panel
Old Sep 4, 2013 | 12:00 PM
aidandj's Avatar
aidandj
Instrument panel
I finally got around to figuring out why my oil light doesn't light up when the key is on. I looked up under the dash and it looks like a piece of the circuit board is broken off around the oil light. the green ends and turns brown all around the light. Am I correct in assuming that I have to replace the entire circuit board to fix this? Its not that big a deal because I have aftermarket gauges, but does anyone know the oil pressure that would turn on the light? I'll probably just mark them on my aftermarket gauge.
Old Sep 4, 2013 | 12:20 PM
JEFFFAFA's Avatar
JEFFFAFA
Well, that would require a new curcuit board. But I am guessing the PO disconnected the dash oil light anyways. He probably unhooked the factory wire and removed the Ford oil pressure sender to install the mechanical gauge. Look end see if I am right or PO tee d the two senders together.
Old Sep 4, 2013 | 12:23 PM
fordfan32's Avatar
fordfan32
It's low around 8-12 psi on idle. I carry remember exactly. But that's pretty standard.
Old Sep 4, 2013 | 12:26 PM
aidandj's Avatar
aidandj
Well the PO t'd the temperature senders so I wouldn't be surprised if he did the same with the oil gauge. I will check this evening.
Old Sep 4, 2013 | 01:35 PM
JEFFFAFA's Avatar
JEFFFAFA
You'll need another curcuit board then. I'm sure the rest of the old one is ready to fall apart. I am sure NumberDummy will chime in soon and give you the part number and places to buy it.
Old Sep 4, 2013 | 02:44 PM
Area351's Avatar
Area351
I have a few clusters if you need any parts.
Let me know.
Old Sep 4, 2013 | 02:51 PM
aidandj's Avatar
aidandj
Let me know.
I'm probably looking for just the circuit board unless you still have any of those fancy gauge clusters from the larger trucks you were showing off in your build thread.
Old Sep 4, 2013 | 04:42 PM
Area351's Avatar
Area351
No F500-700 clusters for sale.
I do have a bunch of F100 clusters for parts though that I'm not going to use.
Old Sep 5, 2013 | 12:10 PM
aidandj's Avatar
aidandj
How much would it cost to get one of those to the Corvallis area?
Old Sep 5, 2013 | 01:15 PM
Area351's Avatar
Area351
What year is your truck?
Old Sep 5, 2013 | 01:23 PM
aidandj's Avatar
aidandj
Its a 1972
Old Sep 5, 2013 | 03:27 PM
Area351's Avatar
Area351
Let me check my stash.
Old Sep 10, 2013 | 01:06 PM
aidandj's Avatar
aidandj
Did you find any?
Old Sep 10, 2013 | 02:30 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I looked up under the dash and it looks like a piece of the circuit board is broken off around the oil light. The green ends and turns brown all around the light.
1971/72 F100/350 (& 1971/74 Econoline): Two different Printed Circuit Boards / 1970 printed circuit boards are 1970 only.
D1TZ-10K843-A .. Use with Oil/Amp GAUGES / Marked: D1TF-10C956-AA / Obsolete ~ 10 available NOS
D1TZ-10K843-B .. Use with Oil/Amp WARNING LAMPS / Marked: D1TF-10C956-BA / Obsolete ~ 9 available NOS
Old Sep 10, 2013 | 02:42 PM
aidandj's Avatar
aidandj
I need the one for the guages
