6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
help
Old Sep 3, 2013 | 11:07 PM
jimknife's Avatar
jimknife
help
Hello. My 08, 6.4 had some hesitation in acceleration. After driving did go away. Had one time killed out, but restarted and ran fine. It continued to exibit the hesitation, or bogging down. Took it to local Ford dealer that has diesel repair. No codes. Checked fuel filter, fresh diesel fuel, checked other items Ford suggested. Still no codes. Tessted hp pump, checked out fine. They 3 or 4 more things to check. One last thing, may pull hp pump. If has rust my extended warranty wouldn't cover. Appropriately $6000. If this is the case would this truck be worth it. About 22, 000 mi. Thanks
Old Sep 4, 2013 | 05:13 AM
senix's Avatar
senix
Sometimes hesitation can be caused by a buildup of moisture in the cac.
But you are saying it did a shutdown?
I don't see how this has to do with a bad hpfp.
Perhaps the low pressure pump but this also seems unlikely.
I had mine replaced under warranty for 3K. No rust or anything.
I had a bad vcv which is part of the pump.
Perhaps they are thinking the wiring to the pump?
Old Sep 4, 2013 | 08:32 AM
cuda66's Avatar
cuda66
I'm with Senix here...fuel pumps would not be my first choice. First thing i would do is drive the vehicle in "info" mode and see if there is a corolation between the hesitation and regen....it is possible that a DPF related component is on its way out etc....
The fact that it runs is a good thing here, its now a matter of seeing what operational system is giving you the problem then going from there...
Old Sep 5, 2013 | 03:55 PM
jimknife's Avatar
jimknife
Update. Wiring harness to hpfp and sensor replaced. Fixed. Thanks for input.
Old Sep 6, 2013 | 08:45 AM
countryboy73703's Avatar
countryboy73703
Personal Props to Senix, and Cuda.
Old Sep 6, 2013 | 09:01 AM
senix's Avatar
senix
Glad you got it fixed.
Claudia Tull
6.7L Power Stroke Diesel
Nov 21, 2016 09:52 AM
dhoff024
Jul 30, 2015 11:58 PM
Dan McMurdo
Jul 18, 2015 12:03 PM
Rich302
Sep 20, 2013 08:52 PM
Jefff H
31
Oct 24, 2012 08:07 AM
