Cool down before shutting off?
Old Sep 5, 2013 | 10:16 AM
Shake-N-Bake's Avatar
Shake-N-Bake
Originally Posted by piotrsko
did a rant couple of years back about EGT gauges and thermocouples in this forum. the slower reacting ones are probably shielded, fast reacting are "bare". CURIE point is only an issue when you are trying to ACCURATELY read 350+/ 50 degrees. BTW the charts say the junction is accurate to 0 degrees F, but the millivolts are so low you need amplification to measure. 1 to 2 % accuracy is a result of manufacturing processes for the gauge unit....
Interesting info. sorry that I missed that thread. So are you saying the metal probe itself may be shielded on the Banks unit and that might be why it's slow reacting? When I got off work yesterday I turned the key to the wait to start position and my overhead console said 111 degrees while my EGT gauge read 50 degrees. Clearly that gauge isn't very accurate at the lower temps. Once I started the engine and drove a few blocks the EGTs readings were over 400 which seemed more normal to me compared to my other trucks.
For comparison's sake...when I got in my F250 pickup this morning (ISSPRO gauges) and turned the key to the Wait To Start position the EGT gauge read about 80 degrees, which is very close to ambient. So, I presume ISSPRO is far more accurate, at least at the lower end of the range.
Old Sep 5, 2013 | 10:25 AM
JOHN2001's Avatar
JOHN2001
This is interesting an very good to know info. With my glowshift gauges at an idle they read around 200* ish on a start up
Old Sep 5, 2013 | 10:38 AM
just another truck's Avatar
just another truck
wow.. my gage, right at the exhaust manifold, idle temp is 390*
Old Sep 5, 2013 | 10:50 AM
Shake-N-Bake
That is about the same as my truck with ISSPRO gauges. It will sit right around 200 ish until I actually start driving somewhere.
Old Sep 5, 2013 | 12:19 PM
grec-o-face's Avatar
grec-o-face
... With my glowshift gauges at an idle they read around 200* ish on a start up
Originally Posted by Shake-N-Bake
... my truck with ISSPRO gauges. It will sit right around 200 ish until I actually start driving somewhere.
My Autometer reads between 225-325 at idle depending on ambient temps.
akblackfoot
Jun 21, 2016 07:47 AM
my996duc1
6.7L Power Stroke Diesel
Nov 12, 2010 11:26 AM
uofmgriz
Feb 8, 2009 02:24 PM
hjew1
Nov 30, 2006 05:39 PM
FX4 CC 4x4
Mar 3, 2004 12:06 PM
