power loss
Old Sep 3, 2013 | 01:05 PM
tcjhkbjt's Avatar
tcjhkbjt
power loss
Here in the last week or so I have noticed what seems like loss of power in my 04 F250 with the 6.0 and has about 175k miles. When I get on the gas it doesnt seems to respond like it used to. When I turn off the truck i can smell diesel a liitle bit. could it just be a clogged injector, bad plugs or what? Any help would be great..
Old Sep 3, 2013 | 01:19 PM
04badford's Avatar
04badford
Any Gauges to read live data? I would pull the EGR and clean it with carb cleaner ,try not to get the electrical side.
And ware your safety Glasses that stuff burns like
Old Sep 3, 2013 | 01:37 PM
tcjhkbjt's Avatar
tcjhkbjt
no gauges, where is the EGR located on that truck? Ill try that first.
Old Sep 3, 2013 | 02:03 PM
tcjhkbjt's Avatar
tcjhkbjt
i did a youtube seach for it and found out how to remove and clean it, ill give it a shot..thanks for the tip...
Old Sep 3, 2013 | 02:06 PM
04badford's Avatar
04badford
Up by the upper fuel and oil filter black round Valve, it will take a 8mm with 6'' extention, I use two small pry bars that you can see in my albums, and Turn counter clock wise pry the valve up ,you should put new O-rings on if they haven't been replaced, I clean my valve with carb cleaner and a plumbers flux brush. dont get carb cleaner in the electrical side, work the valve theres two discs clean inbetween those too.
BrookFutureDieselTEC
Aug 8, 2012 02:12 AM
claytonc
Apr 6, 2011 09:13 PM
macstrailers
Mar 5, 2011 02:28 PM
tqii42
Apr 22, 2009 01:44 PM
bhillis
Aug 3, 2007 09:47 AM
