Bonnet won't open?
Old Sep 1, 2013 | 01:06 AM
xran's Avatar
xran
Bonnet won't open?
Hey fellas,
My bonnet has jammed itself closed somehow on my '74... Has this happened to anyone else and do any of you know how to pry it open again?? It isn't the spring jamming up, I've had that previously. This time the lever won't even pop it open to the first click, it's somehow completely jammed shut
Help before I get the sabre saw and make a mess of my nice new radiator support panel!!
Cheers,
Jais
PS will also post this into the aussie chapter forum
Old Sep 1, 2013 | 01:07 AM
xran's Avatar
xran
PPS - I think what we call a sabre saw is what you guys call a saws-all....
Old Sep 1, 2013 | 01:17 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Try pulling the release latch with one hand and at the same time hit the hood just above the latch with your other fist, it may take a pretty good hit.
Old Sep 1, 2013 | 01:49 AM
montana_highboy's Avatar
montana_highboy
Originally Posted by xran
Hey fellas,
My bonnet has jammed itself closed somehow... Has this happened to anyone else and do any of you know how to pry it open again?
An apology... accompanied with chocolates and flowers usually works for me.
Old Sep 1, 2013 | 02:30 AM
WhoaFiveOh's Avatar
WhoaFiveOh
Faster than me!
Mike beat me to it! I had to do the same thing to my 74 yesterday. A good pop with your fist should hopefully free it up. Good Luck!
Old Sep 1, 2013 | 07:44 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Try just applying downward pressure to the middle of the hood (right above the latch) and then release it. Do not over torque the release handle, they will bend.
Otherwise you might be able to unbolt the complete latch assembly thru the grill?
Old Sep 1, 2013 | 02:04 PM
LxMan1's Avatar
LxMan1
We also call the bonnet a hood over here
Old Sep 1, 2013 | 04:49 PM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
No fists! Use your forearms with a firm burst of pressure on the edge where the metal creases. Otherwise you will dent it in a way which is only obvious from the side looking across.
I have seen hundreds of trucks with "fist" dings peppered all over the nose of the bonnet!
Do it right or do it wrong it's up to you.
Old Sep 1, 2013 | 07:13 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I agree, I should have worded it better.
Old Apr 14, 2014 | 10:06 AM
xran's Avatar
xran
thanks guys got it by pulling the grille apart and unbolting the latch assembly.
now it sits really really high... I replaced the hinges with a pair that were fine on an XLT I pulled apart a while ago and fixed the latch, but yeah it sits super high, there's about 1.5" gap between it and the guard. If you press it down it sits where it should but then it springs back up again... for now I've just raised the latch to make it sit evenly but it's driving me nuts.
Has this happened to anyone else? How did you fix it? Adjusting the hinges up and down doesn't seem to make any difference...
Cheers
Old Apr 14, 2014 | 11:08 AM
78 PEB's Avatar
78 PEB
Make sure your hinges are lubed up good and not binding. Lube every pivot point on them with WD40 or good penetrating oil and work the hood up and down. Repeat till it works smoothly. I have found that if the hinges are sticky, it will make the hood hard to open and will not allow the rear of the hood to go fully down when you close it. After you get it working right, lube it all up with spray type white lithium grease. I usually lube all of it up every time I change my engine oil to keep it from happening again. Hope this helps!!
Old Apr 14, 2014 | 11:14 AM
Bud Mud's Avatar
Bud Mud
LMAO! It took me a few minutes to figure out what the bonnet is.
Old Apr 14, 2014 | 02:27 PM
arthurfelter's Avatar
arthurfelter
I learned all of this terminology from Top Gear (the UK version). Any Top Gear fans here?
Old Apr 14, 2014 | 02:31 PM
Bud Mud's Avatar
Bud Mud
Just so you know,im not laughing at you,just never herd the hood called that.
Old Apr 16, 2014 | 12:47 PM
xran's Avatar
xran
hahaha the hood is the roof lining over here :P (or the part of the anatomy that houses the clitoris LOL)
Thanks PEB, I'll try giving it some more lube again. I drowned them in WD40 before bolting them on and when that dried out I sprayed a HEAP of Lanolin on it all so they'd work smoothly but it didn't make any difference to where it sat. I'm home in 3wks so I'll let you know how I go when it happens
