injector cup longevity question
Old Aug 30, 2013 | 04:45 PM
MONAVIERONJON's Avatar
MONAVIERONJON
Been thinking about what the lead contributing factor for cracked injector cups. Would it be age/ fatigue, defective production run, metal composite, running bigger injectors, or scenarios with decked heads and higher compresion? certainly someone has knowledge in this realm, thankx, Ronjon
Old Aug 30, 2013 | 05:13 PM
Groundpounder0331's Avatar
Groundpounder0331
My number #8 cylinder inj cup developed one small hairline crack at 180K. I don't believe it was due to a defective product but just normal wear and tear. I think there is a possibility improper SCA levels may influence cracks and pinholes but I'm not certain. Are your's bad?
Old Aug 30, 2013 | 07:33 PM
MONAVIERONJON
got a rebuild going on and just ordered new cups. The heads will then be brand new as already did the comp cams 910-16 springs, and new seals and intakes. Just curious, and this is a spare motor so did not have any symptoms, although had 210k on the motor.
Old Aug 30, 2013 | 11:20 PM
Groundpounder0331
It's funny as I just had my injectors out about four months ago when I installed new O-rings, and the cups were fine. I pressurized the system then and there were no leaks. I removed my injectors a month ago as they were not seated properly, (operator error) . I repressurized the system and found one leaking cup, but it wasn't from the same sleeve the improperly sealed injectors came out of. So even if I had properly seated my injectors the first time, I had a serious problem underway. I can smell the diesel in my coolant because of this leak.
Olds64
Nov 6, 2018 10:38 AM
dwdranch
May 15, 2013 07:24 AM
jedlane8870
Aug 15, 2012 10:12 PM
99hunter
Nov 22, 2009 09:14 PM
Jerrod
Feb 20, 2006 07:33 AM
