help with engine
Old Sep 4, 2013 | 05:20 PM
  #31
46yblock's Avatar
46yblock
I had this picture of a 2100 from under my desk ready to go in case the ID of yours wasnt shown. This one is a 1967 Galaxie 390 unit.
<a href="http://s1225.photobucket.com/user/46yblock/media/duct_zpsc7b71c02.jpg.html" target="_blank"><img src="http://i1225.photobucket.com/albums/ee388/46yblock/duct_zpsc7b71c02.jpg" border="0" alt=" photo duct_zpsc7b71c02.jpg"/></a>
Old Sep 5, 2013 | 04:24 PM
  #32
capelo's Avatar
capelo
Originally Posted by hiball3985
The engine looks in good condition, it is fine for your truck..
Is that the oil pump drive sitting in the valley? It's missing a piece that prevents it from coming out of the pump when you pull the distributor out.
do not quite understand what I mean
Old Sep 5, 2013 | 04:33 PM
  #33
capelo's Avatar
capelo
well, I'm looking for a better heads and something I have already looked on the carburetor and distributor, who advise, if I put my distributor electronic ignition kit would serve?
Old Sep 5, 2013 | 04:37 PM
  #34
capelo's Avatar
capelo
46 block, thanks for the data of the carburetor, and seen by the bottom few numbers "10 10, 68 ' may be a date
Old Sep 5, 2013 | 04:42 PM
  #35
capelo's Avatar
capelo
a video of the engine running before dismantling:
Old Sep 5, 2013 | 05:00 PM
  #36
hiball3985's Avatar
hiball3985
The oil pump drive should not come out through the top when you take out the distributor. It should only come out of the bottom when you remove the oil pump. There is a spring type washer that should be on the drive shaft too prevent this from happening, you are missing that piece. Sorry I can't post a picture, maybe someone else can do that. maybe you can see this
http://www.ebay.com/itm/Oil-Pump-Shaft-Ford-272-292-312-341-368-Y-Block-Mercury-Drive-Driveshaft-New-/221150745401?pt=Motors_Car_Truck_Parts_Accessories&hash=item337d9c9339&vxp=mtr
Can't view the video, it says its private and I don't have a youtube account..
Old Sep 6, 2013 | 01:08 AM
  #37
capelo's Avatar
capelo
ok now I understand. if it came out the rod with the dealer. yenia not the washer and was somewhat worn. and asked for a move and ARP
Old Sep 6, 2013 | 06:02 AM
  #38
The Horvaths's Avatar
The Horvaths
The ARP rod is much stronger. Strangely, they have been packaging the ARP rod with the retaining washer installed on the wrong end of the rod. You can slip it off and put it on the other end. It should fit well within the distributor and oil pump. If it does not fit well, try reversing it.
Old Sep 6, 2013 | 08:20 AM
  #39
hiball3985's Avatar
hiball3985
A little off topic: I had an oil pump on a 302 lock up and stock rod twisted like a pretzel but it didn't break . I just bought a replacement one for the 292 I'm building and it was assembled wrong and I had to turn the washer around and put it on the other end so it not just ARP unless they all come from the same supplier.
Old Sep 6, 2013 | 03:37 PM
  #40
capelo's Avatar
capelo
no one can see the video?
Old Sep 6, 2013 | 03:46 PM
  #41
charliemccraney's Avatar
charliemccraney
I can't see the video. It is indicated as private.
Old Sep 6, 2013 | 04:23 PM
  #42
Y-Blockhead's Avatar
Y-Blockhead
I doubt it. The ARP is much more robust then a stock replacement, only the ends are hex. And ARP is etched into the round 'body'.
Always put the beveled or 'pointed end' toward the distributor with the clip on the opposite end (bottom). The pointed end helps guide the rod into the bottom of the distributor.
Old Sep 6, 2013 | 04:30 PM
  #43
hiball3985's Avatar
hiball3985
Originally Posted by Y-Blockhead
I doubt it. The ARP is much more robust the a stack replacement, only the ends are hex. And ARP is etched into the round 'body'.
I think the clip goes on the top/pointed end, if it was on the bottom it would pull from the pump.
OK, I see the difference, I've never used the ARP. Its strange that both ARP and other suppliers all get it backwards
Old Sep 6, 2013 | 04:56 PM
  #44
arctic y block's Avatar
arctic y block
No I can not see the video either
Others have had this problem and went back to there video and
changed something than everyone could see it.
There must be a way to make it public as it said it was a private video.
Old Sep 6, 2013 | 10:54 PM
  #45
Y-Blockhead
Nope, the clip goes on the bottom to prevent the rod from coming out when the distributor is pulled.
Capelo, I just noticed in your first picture of the engine, your dipstick is in the incorrect position. It needs to be on the side of the block so it goes into the pan sump. The position it is in now is for a car pan with a front sump.
