Has anyone ever use ahydro boost off a 78 lincoln .I just found this car with the saginaw pump and lines , car has disk brakes and rear drums has so brake proposing valve on my 76 4x4 should work.I Think this maybe a simple r&r if not somebody stop me soon thank you
As long as your booster fits on your firewall, I think you should be able to make it work.
My hydroboost unit is off of a Superduty of some particular year that I could probably look up...but I had to have an adapter to fit it on my '79 Bronco.
ya i hoping this would be the ezest way to go with no fab work.A new hydro boost for that year under $200 and let say 50 for saginaw pump you cant beat that if you can just it bolt it in
