2000 Excursion 7.3 Remove and Replace No Start Condition
Old Aug 30, 2013 | 09:18 AM
zeppelingto's Avatar
zeppelingto
Working on a 2000 Excursion with a 7.3 that I am currently experiencing a no start condition with.
I had driven the truck for about 1,000 miles with an annoying SES light for glow plug #6. I went to replace the glow plug but it got stuck in the head. I removed the head and pulled out the plug. When I removed the head to my horror one piston was missing a chunck out of it. The truck had no blow by and ran great (got good mileage too!).
I pulled the motor replaced the one bad piston and the oil pan. Then I put the motor back and it will crank but not start.
I can get the truck to run on brake clean but nothing else. It seems like no fuel is being sent to the injectors.
As of now I get no codes except for p0605 internal ROM fault.
My ICP climbs to 18,000 psi and the IPR duty cycle goes to 46%.
Seems to have everything connected right...
Old Aug 30, 2013 | 09:22 AM
USMCJosh's Avatar
USMCJosh
ROM is "Read Only Memory" and refers to the type of memory your PCM has. You may have a PCM issue.
Old Aug 30, 2013 | 09:34 AM
zeppelingto
I dont know why it would all of a sudden have a bad pcm? Everyone I have taled to has said that they havent seen that code cause a no start.
Old Aug 30, 2013 | 09:59 AM
Shake-N-Bake's Avatar
Shake-N-Bake
18,000 psi is an awful lot for the PCM to be reporting. Something doesn't seem right there.
Here is a good no-start troubleshooting guide.
File Type: pdf
Old Aug 30, 2013 | 10:04 AM
JT250's Avatar
JT250
Just what I was thinking...you sure it is not 1800 psi?
Old Aug 30, 2013 | 10:05 AM
JT250's Avatar
JT250
How long have you cranked on it? It takes a while to start after doing work of that kind.
Old Aug 30, 2013 | 12:14 PM
Christof13T's Avatar
Christof13T
It can take quite some time to get the oil galleys all primed back up...
Keep a battery charger handy...
Crank for no more than 30 seconds at a time and let it cool off before the next try. Give it a good 10-15min between cranking.
You can sometimes speed up the process by filling the hpop reservoir but it shouldnt be necessary if the lpop is working.
Old Aug 30, 2013 | 12:27 PM
SkySkiJason's Avatar
SkySkiJason
I agree, except if there is fuel and power to the injectors, they will generally fire off the MOMENT ICP hits 500psi.
First thing I'd do is open fuel bowl drain and turn on the key to see if pump is working. Pump will time out after ~30secs if the engine doesn't start.
The link S&B posted should get ya there as well.
Oh, and unless you like pistons missing chunks (or WORSE) - STOP using brake clean to make your engine run!!!
Old Oct 16, 2013 | 11:36 PM
zeppelingto
Fuel lines were switched. I ended up replacing injectors and cleaning fuel lines, but the fuel supply and return lines were switched.
Old Oct 18, 2013 | 10:51 PM
JT250's Avatar
JT250
Thanks for the update
lucasw87
Apr 15, 2015 04:10 PM
22fordguy
18
Sep 17, 2014 10:07 PM
dand24u
18
Apr 8, 2009 11:13 AM
