2000 expy p0442 trouble code help
Old Aug 29, 2013 | 07:31 PM
kerim1's Avatar
kerim1
Hi i have a 2000 expy 4.6 2wd 171000 miles
my check engine light has been on for a few weeks, i had it scanned today and the code P0442 came up.
I have already checked all of the hoses around the engine and behind the battery, the elbow assembly behind the throttle body has been replaced last year. car runs drives and idles great.
What else could i check?
(i have checked the fuel cap)
the serpentine belt broke 2 weeks ago while driving, i thought that maybe this caused to knock off one of the hoses but i don't see anything broken or loose.
Thanks
kerim
Old Aug 30, 2013 | 07:30 AM
BAD RONALD's Avatar
BAD RONALD
Take a look at this thread:
https://www.ford-trucks.com/forums/1...150-5-4-a.html
Also search "evap" for ideas.
I have an '04 E350 that throws this code a couple of times a year, so I kinda keep an eye on the boards for a fix. Because the vent problem on the van is intermittent, when the code isn't present it passes emissions. Since whatever leak exists does not effect the way the engine runs, for me this repair keeps getting bumped.
Old Aug 30, 2013 | 05:47 PM
kerim1's Avatar
kerim1
thank you for the link,
today i visually inspected all of the lines i started all the way in the rear of the vehicle and followed the lines up front to the engine, everything looked good visually, i have also checked all fuses.
does anyone know how i can test the evap components to see if they are operating the way they should?
Thank you
Kerim
Old Aug 30, 2013 | 06:30 PM
projectSHO89's Avatar
projectSHO89
P0442
Take it to a shop for a smoke test. Otherwise, all you can do is guess in the following order.
Clean/inspect the gas cap and its seating surfaces.
Inspect/clean the Canister Vent valve.
Replace the gas cap with an exact Motorcraft replacement.
Replace the vent valve with a new vent valve.
...then take it to a shop for a smoke test to find the small evap leak.
Old Aug 30, 2013 | 07:32 PM
kerim1's Avatar
kerim1
i guess i'll just take it to a shop to have the smoke test done.
thank you.
Old Aug 31, 2013 | 05:44 AM
projectSHO89
Call around. Not every independent shop has a smoker.
Old Aug 31, 2013 | 07:44 PM
kerim1's Avatar
kerim1
the local shop in my small town has one, he said that he would do it for around $35, now i just have to find the time to take the car in.
Thanks
gogreenwave
Feb 13, 2015 09:10 AM
SC_Hoaty
Oct 10, 2014 07:49 PM
lincolnboy73
Aug 31, 2010 06:56 AM
jstang95
1997 - 2003 F150
Feb 21, 2005 09:24 PM
330design
1997 - 2003 F150
Jun 28, 2004 09:56 PM
