What's the preferred method for straightening the steering wheel? Wheels off the ground, on the ground? Which way to turn the drag link collar, pull down or push up?
Mike
When I did mine a while back, I just backed up a bit then pulled the truck forward so it was going straight and the wheels were straight. I then disconnected the drag link from the pitman arm and straightened out the steering wheel. Then I loosened the sleeve and adjusted the tie rod end of the link accordingly and bolted it back to the pitman arm. I did this all with all four wheels on the ground.
Dennis' method will work, but it's not necessary to disconnect from the pitman arm. Just drive the truck forward until the wheels are pointing straight, loosen the two bolts on the adjusting sleeve and rotate the sleeve with some vice grips. Just turn it 1/2 turn and see where the wheel is at, and adjust from there.
It will probably take you ~5-10 minutes, it's easier than an oil change!
Cool thanks, Tom. I'll have to try that next time around
Oh, yeah- Michigan and salt ! The more salt they use, the faster your vehicles rot away ! The car makers pay the road commission to use extra salt, so you have to buy a new car every couple of years. All my cars rotted away in 3 or 4 years.
And then after all of that. They want to know why bridges fall down.
That is other than you occasional trucker smacking one on I-5 in Washington
or tanker fires around San Francisco.
Then ................... Mar 29, 2007 - Rosie O'Donnell is certainly not backing away from her public stance ... and if America doesn't
stand up we're in big trouble," says O'Donnell. ... "No, but I do believe it's the first time in history that fire has melted steel
She does have a good point and if we don't stand up to things it will only get worse.
One of the best methods I found to get the steering wheel perfectly straight is to pop the drag link off the pitman arm, straighten the steering wheel, chock the wheels (one on the front side of the tire and one rear side the tire), adjust the drag link so it fits exactly to the pitman arm without moving the wheels (the wheel chocks help with this) or steering wheel and finally reattach the drag link to the pitman arm.
Yes it sounds like a lot of work but I find it's easier to do this then to chase the adjustment which I always do. Also it drives me bonkers to have the wheel even slightly off center and I find that this way I can get it perfect.
Thanks guys, I'm going the easy?? route with the adjuster sleeve and vice grips or a pipe wrench. I don't have a gear puller handy to pop the pitman arm off.
Mike
Smack the pitman arm with a hammer, the ball joint will pop out.
I've done that with stubborn balljoints in the past, but the steering gear is a bit more sensitive to impact than a control arm. No way, no how, not EVER would I do that unless I was planning on replacing the steering gear.
A Lisle puller is only $22.80 shipped on Amazon.com. Far cheaper than a new steering gear or a new truck if you crack your sector shaft and wreck it.
